![]() | Home > In Car Electronics > gps for ipad |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Done!
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 ![]() ![]() ![]() |
Border terrier- that's great thanks! You found the codes before I had time to respond to the other post!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5822 ![]() ![]() |
My mount shown here
http://www.defender2.net/forum/topic23395.html Andy |
Hi Andy- I was looking at your post last night, it looks spot on. Just struggling with the size of iPad mini with case, it's just slightly too big for the ram mounts for the mini. They seem to cater for sleeve but not a rubber case.
Martin |
Rob - photo of mine so you can keep your eye out for me.
Any good. http://www.tallonsystems.com/products/view...et_holder/ Andy |
Like the look of that link but again it doesn't give max dimensions. iPad mini with case on is 6" wide.
May have to do that. The size 85x180x95 doesn't make any sense, iPad with case is 215 x 150.
Martin |
Here you go
The RAM X-Grip II™ has a clean and clever four leg design that sports great holding power without hiding your tablet behind foam pads and plastic. The perfect compliment to the modern sleek design of tablets, the RAM X-Grip II™ is the tablet holder evolved. Compatible and interchangeable with a wide range of popular RAM Mounting products, this elegant universal holder is ready to compliment your tablet. The RAM-HOL-UN8B consists of a spring loaded holder and 1" rubber ball connected to the back. Easy access grip knobs are located on the back of the holder for quick release of your tablet. The RAM-HOL-UN8B expands and contracts for perfect fit of most 7" tablets. Compatible Devices: Apple iPad mini Amazon Kindle Amazon Kindle Fire Amazon Kindle Fire HD Archos 7 Asus EEE Pad Memo Barnes & Noble NOOKcolor BlackBerry PlayBook Dell Streak 7 HTC Flyer Panasonic Toughpad™ JT-B1 Samsung Galaxy Note 8.0 Samsung Galaxy Tab (7" version) Samsung Galaxy Tab 7.0 Plus Samsung Galaxy Tab 2 7.0 All devices that maintain the following dimensions below Holder Dimensions: Minimum Width = 57.15mm (Devices 57.15mm in width must be a minimum of 177.8mm in height to fit) Maximum Width = 146.05mm Depth = 22.22mm Features: 1. Spring loaded holder expands and contracts for perfect fit of your tablet 2. Rubber coated tips will hold your tablet firmly 3. Versatility of holder allows for attachment to many RAM-to-RAM ball and 1" socket mounts 4. Socket technology allows for multiple adjustment angles and articulation of your tablet 5. Easy access grip knobs, located on the back of the holder for quick release of your tablet Material: High Strength Composite with Rubber Tips Ball Size: 1" Rubber Ball "B" Size |
That's the one I was looking at but it's max width is 146.5mm, mine is 150 with the case on.
Not sure if a bigger one would adjust small enough. Martin |
Next one up is too big. 158.75mm. Min.
Andy |
Wonder how accurate the 146.05mm is, no doubt ram been ram it will be spot on.
Cheers for the help on this. Martin |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 ![]() |
RAM all the way for me... I have one for an iPad Mini and it is a great setup with Memory Map and TomTom for offroad and onroad navigation
![]() You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
