Home > In Car Electronics > gps for ipad
Page 2 of 3 <123>
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I've never done it (I have a 3G/GPS iPad) but there seems to be plenty of info via Google.
http://www.guidemyjailbreak.com/
...as an example.
Do it at your own risk. Or sell iPad and get one with it built in..Smile
Simon
Post #318772 24th Mar 2014 6:53pm
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi
I have an iPad air WIFI only and have it linked via Bluetooth to a DUAL XGPS150E GPS receiver. Great piece of kit, fast connection time (fast enough for me anyway), accurate and exceptionally easy to pair it to the iPad in Bluetooth settings. Recognised it straight away. Happily sits on my TD5 dash in its anti-slip mount and comes supplied with USB charging socket for the lighter. Cost around £90, which I considered value for money given the increase in functionality of our existing iPad.
(for a GPS app I opted for memory map, but that's another story.) All I need to do now is to see whether I can cache aerial photos from Google Earth onto the iPad.
Rob
Post #319371 26th Mar 2014 10:00pm
deplec
United Kingdom 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
I use a Brodit pro clip to hold it and iPad mini cellular (which has the GPS chip per the above). I then use the View Ranger app and just buy the OS squares I need, when I need them. I use free maps from Apple/Google for any sat nav needs. The brodit clip is very stable. I think the iPad mini is better that the full sized iPad for in car use. The iPad mini is also 4G enabled, but I don't go near anywhere with coverage for that very often... Cheers.
Post #319390 26th Mar 2014 10:52pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Hi - can I ask which brodit clip and mount you use?
Post #319396 26th Mar 2014 11:06pm
Blacktt600
Rob - how have you fixed your iPad to the dash? Assuming you have. Notice your from Pudsey, I'm just down the road in Farsley!
Martin
Post #319401 26th Mar 2014 11:22pm
deplec
Hi - I bought the 2nd one down on this page.
http://www.dsldevelopments.com/brodit/hold...Holder.asp
Passive with no charger built in and no lock.
The mount screws to the universal base which is attached to the dash without damage.
Expensive I thought, but it does just the job.
Looks like this:
Post #319421 27th Mar 2014 7:28am
landy andy
If anybody wants a holder for an iPad let me know as I've got one I don't use.
Andy
Post #319429 27th Mar 2014 7:59am
Blacktt600
I'm needing a holder for iPad mini with a rubber case on. I'm struggling to find one at the moment owing to the rubber case which makes it wider than the norm. Have looked at ram Xgrip but that only takes up to 5 3/4 ", mine is 6" with the case.
Martin
Post #319446 27th Mar 2014 9:23am
DC101
Martin,
Great to hear from a D2 member local to me!
My ipad air currently has the passenger lap mounting system, but will hopefully one day upgrade (don't tell her!) to the RAM system seat mounting arm and xgrip III which will accommodate a 10" tablet . Brendon (LEEDS) is the man for RAM mounts and not far from us either.
Rob
Post #319618 27th Mar 2014 9:56pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Martin
Here is my set up for a mini iPad with Griffin case
Post #319624 27th Mar 2014 10:05pm
Blacktt600
Border terrier - that's where I'm thinking of mounting mine. Been looking on ram site but slightly overwhelmed with the choices! Don't suppose you have the codes / part numbers to hand? I gave the bis battery monitor just below this as well so would have to double check the measurements.
Martin
Post #319635 27th Mar 2014 10:20pm
borderterrier
Can it wait ill morning mate?
Post #319636 27th Mar 2014 10:21pm
Blacktt600
Hi Rob. Not sure on the seat mounting option, I use my 110 for work and can imagine it getting in the way more than it would be worth. Sure I must have come across your motor before now - what is it you drive? I'll post a photo of mine later so you can keep your eye out for me. It's sign written black 110 csw with patriot rack on. I purchased one or two things from Brendan recently (top bloke) but wanted to be sure what I needed before I ask him.
Martin
Post #319638 27th Mar 2014 10:26pm
borderterrier
Post #319642 27th Mar 2014 10:28pm
Blacktt600
Tomorrow would be great thanks.
Post #319643 27th Mar 2014 10:28pm
Page 2 of 3 <123>
