Home > In Car Electronics > gps for ipad |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I've never done it (I have a 3G/GPS iPad) but there seems to be plenty of info via Google.
http://www.guidemyjailbreak.com/ ...as an example. Do it at your own risk. Or sell iPad and get one with it built in.. Cheers Simon |
24th Mar 2014 6:53pm |
deplec Member Since: 21 Aug 2012 Location: Yorkshire Posts: 152 |
I use a Brodit pro clip to hold it and iPad mini cellular (which has the GPS chip per the above). I then use the View Ranger app and just buy the OS squares I need, when I need them. I use free maps from Apple/Google for any sat nav needs. The brodit clip is very stable. I think the iPad mini is better that the full sized iPad for in car use. The iPad mini is also 4G enabled, but I don't go near anywhere with coverage for that very often... Cheers.
26th Mar 2014 10:52pm |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 |
26th Mar 2014 11:06pm |
Rob - how have you fixed your iPad to the dash? Assuming you have. Notice your from Pudsey, I'm just down the road in Farsley!
Martin |
26th Mar 2014 11:22pm |
Hi - I bought the 2nd one down on this page. http://www.dsldevelopments.com/brodit/hold...Holder.asp Passive with no charger built in and no lock. The mount screws to the universal base which is attached to the dash without damage. Expensive I thought, but it does just the job. Looks like this: Cheers |
27th Mar 2014 7:28am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5739 |
If anybody wants a holder for an iPad let me know as I've got one I don't use.
Andy |
27th Mar 2014 7:59am |
I'm needing a holder for iPad mini with a rubber case on. I'm struggling to find one at the moment owing to the rubber case which makes it wider than the norm. Have looked at ram Xgrip but that only takes up to 5 3/4 ", mine is 6" with the case.
Martin |
27th Mar 2014 9:23am |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 |
Martin,
Great to hear from a D2 member local to me! My ipad air currently has the passenger lap mounting system, but will hopefully one day upgrade (don't tell her!) to the RAM system seat mounting arm and xgrip III which will accommodate a 10" tablet . Brendon (LEEDS) is the man for RAM mounts and not far from us either. Cheers Rob |
27th Mar 2014 9:56pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Here is my set up for a mini iPad with Griffin case Click image to enlarge Click image to enlarge |
27th Mar 2014 10:05pm |
Border terrier - that's where I'm thinking of mounting mine. Been looking on ram site but slightly overwhelmed with the choices! Don't suppose you have the codes / part numbers to hand? I gave the bis battery monitor just below this as well so would have to double check the measurements.
Martin |
27th Mar 2014 10:20pm |
Can it wait ill morning mate?
27th Mar 2014 10:21pm |
Hi Rob. Not sure on the seat mounting option, I use my 110 for work and can imagine it getting in the way more than it would be worth. Sure I must have come across your motor before now - what is it you drive? I'll post a photo of mine later so you can keep your eye out for me. It's sign written black 110 csw with patriot rack on. I purchased one or two things from Brendan recently (top bloke) but wanted to be sure what I needed before I ask him.
Martin |
27th Mar 2014 10:26pm |
http://www.ram-mount.co.uk/2-x-17-adapter-...8_286.html
http://www.ram-mount.co.uk/diamond-base-wi...8_286.html http://www.ram-mount.co.uk/double-socket-a...8_286.html http://www.ram-mount.co.uk/tabtite%C3%82%E...0_673.html There you go. It's rock solid. The flexible arms move off road. Last edited by borderterrier on 27th Mar 2014 10:29pm. Edited 1 time in total |
27th Mar 2014 10:28pm |
Tomorrow would be great thanks.
