Home > Td5 > Defender td5 flat under load after bigger intercooler
Defender LAF
United Kingdom 1999 Defender 90 Td5 PU Rutland Red
Recently fitted a bigger intercooler it has made a difference, however quite often under hard acceleration or when I change gear and go full tilt again my Landy goes flat a smokes more and just doesn't sound the same or even happy if you know what I mean, especially when towing, maf meter is fine, and usually if I lift off and go again it's fine? Turbo is standard and at standard psi. Any ideas?
Post #313652 4th Mar 2014 11:14pm
will need one of the tuning boffins to confirm this, but it could be that the larger I/C is doing its job... cooling the air, which makes it denser.
Thus the MAF is is getting more air through it at any given revs than it can handle, and freaks out (they have upper limits as to what air flow they can compute) and so is giving the ECU the signal to back off a bit.
Mine does it with raised boost, You can get modified MAF's I think, certainly different boost boxes (IRB does them) that allows the MAF to cope with greater volumes of air.
Post #313713 5th Mar 2014 12:13pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Are your hoses before the turbo still in good shape? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #313782 5th Mar 2014 6:05pm
Defender LAF
I'll check the hoses before the turbo didn't even think of those? Embarassed I did check the intercooler pipes and they are fine.
Post #313799 5th Mar 2014 7:37pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Also bear in mind that the larger inter cooler is a larger pressure vessel that your turbo needs to fill, your turbo with standard boost will struggle to fill it and maintain pressure so you will get more lag. www.td5.org
Post #313826 5th Mar 2014 8:47pm
Defender LAF
Will it reduce the life of the turbo much if I changed the pressure, and if I did that would I then need a boost box? Thanks for your help so far Thumbs Up
Post #313857 5th Mar 2014 11:35pm
Defender LAF
Checked all pipes and hoses are good, and seem fine.
Post #314139 6th Mar 2014 10:45pm
Defender LAF
Been looking at boost boxes from alive and tmd, both sound as if they would cure my problem by adjusting waste gate and using a box, which would you buy? Confused
Post #314912 9th Mar 2014 11:37pm
landy andy
Alive for me, great support and knowledge. Have had three of his remaps, and can't fault them.
Andy
Post #314922 10th Mar 2014 6:40am
fixit
When you changed the intercooler was it remapped?
I would have thought that to get the best out of it then just changing the intercooler isn't going to do much as its not going to have the right air to diesel ratio
Mine has a full size intercooler and boost box running 1.5 bar and is remapped to suit but i have not tried one without the other
I would think your best off asking Gary at Alive he is very helpful as there is no point buying more bits to try unless its going to sort it
Mine had a moment a little while back sounds a bit like your problems and it turned out to be the airflow meter
You may know already but you can unplug the airflow meter and drive it won't go like it should but it will drive ok and if the symptoms are different then its prob just that.
Post #315057 10th Mar 2014 7:01pm
fixit
It could also be the waste gate sticking and over boosting
I would have a look at that as well but i woudn't adjust it with out a gauge and it would pay to put one on first so you can see whats going on as a little is a lot on the rod lenght
Post #315060 10th Mar 2014 7:08pm
Defender LAF
Its chipped, egr removed, silicone hoses, and pipercross filter, it use to go like a rocket but is just abit sluggish now after a bigger intercooler, MAF has been unplugged for afew days and doesn't seem any different to drive. I do spray abit of wd40 on the turbo actuater now and then i will give it another check.
Post #315107 10th Mar 2014 8:50pm
