Home > Puma (Tdci) > 2.2 XS, Can you switch off the Traction Control?
Page 5 of 5 <12345
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Agreed, in normal situations you wouldn't attempt climbs that you know will fail. It's a bit different in competitions when Alpha Male syndrome kicks in.
I've seen some scary reverse decents when reverse hasn't been selected quick enough and the vehicles slides down with all four wheels locked, out of control. My method may be not be text book, but it works in extreme situations.
Post #314335 7th Mar 2014 7:02pm
jst
text book is dont use the handbrake on a failed climb.
as you mention key advantage of the transmission handbrake and CDL locked is benefit of a wheel being braked on the front and rear axle, which is good for off road parking (left in gear and engine off etc) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #315755 13th Mar 2014 10:13pm
Page 5 of 5 <12345
