![]() | Home > Td5 > what mileage |
Ragerover Member Since: 26 Dec 2013 Location: In a land far far away Posts: 145 ![]() ![]() |
My 90 has 158k miles
Well tuned and well thrashed With regular servicing runs sweet I think the initial panic over reliability was a fallacy Obliviously standard faults like injector harness and FPR. But nowt major Only dreaded metal worm ![]() |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
My 2003 90 td5 has 131000 miles on it now.
Alive Stage 1 remap since 110k ish (miles per gallon and smiles per gallon both gone up) Driven hard on the road, and used off road. Engine wise, regular servicing and I've hardly had to touch it with a spanner. Fuel pressure regulator went at about 60k iirc, replaced with new and not had a problem since. Manifold warped shortly after remapping, skimmed and refitted, but believe I may still have a leak so either redo or think about an Allisport one. Clutch and DMF could do with being replaced, no slip as such but it judders and groans occasionally so probably more a release bearing if anything. As it's all got to come off, I think im going to just bite the bullet and get the tbox rebuilt with 1.2 ratio (disco gearing) and contemplating getting the gbox reconned while its out too at this mileage (plan on keeping it). I agree with 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 ![]() ![]() ![]() |
Mine is a relative baby, 2004 68000 miles. Replaced the injector harness and seals and it runs beautifully. My last one 2002 sold at 80000 same as above, ran with no problems. Love the TD5, such a great sound.
Obviously everything around the engine is falling apart but hey ho.... ![]() |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Sounds as though I have got a vehicle with Hugh potential for work and mileage
![]() Prior to getting mine the dealer replaced clutch and DMF (nice) and I think I have learnt a lesson regarding driving style as it responds well to hard driving!! Tommo |
As stated on another thread.....
I doubt if there are (m)any forum members that cover the mileage per annum that noworries4x4 does in his Defender(s). Drop him a 'pm' perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
01 90 csw with 81k on at the moment, sold my stage 2 04 90 xs in June with 77k
vodonos Member Since: 13 Jan 2013 Location: CERKNICA LAKE Posts: 29 ![]() ![]() ![]() |
Mine 2001 90, have now 248.000 km, change fuell pressure regulator and head harness at 120.00. Clutch at 200.000 km. Drive like new
![]() Best regrds BOŠTJAN SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
DanielSon Member Since: 24 Jan 2014 Location: Swansea Posts: 7 ![]() ![]() ![]() |
Hi ,, im a newbie so hello all..
my defender done 135k and it drives very good |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Got an opportunity and been looking at a 52 plate 90 2003 td5. 150,000 miles. I am not mechanical minded, will take my brother to look as he is if that mindset. Looking to do say 5,000 a year in it as a second car.
Can you point me to some areas (excluding bodywork) where I should focus on to ensure it's running right? Tack |
DCFerret Member Since: 23 Jan 2014 Location: Norfolk Posts: 8 ![]() ![]() ![]() |
2003 110 DC with 102k on it, had the injector harness done at 99k just after I bought it and currently in hospital having a recon gearbox, transfer box and clutch fitted, DMF is ok so that's one less expense. Also having an electrical fault with the accelerator pedal looked at at the same time, keeps putting the MIL light on after driving through any puddles!!
shazzy90 Member Since: 17 Dec 2010 Location: tyneside Posts: 489 ![]() |
my 110 has117,000 now and had a new clutch ,i once had a 1999 td5 disco in 2002 with 136,000 on the clock , then i did a deal with well known independent dealer for a 1999 90 with 83,000 on clock , 18 months later the same dealer was selling my same discovery with a lot of upgrades, with only 82,000 miles ,well i was mad ,my main thought was how many miles did the 90 really have,well as it happened i took the 90 to 128,000 with no problems
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 ![]() ![]() |
@shazzy90
Wonder how common that sort of thing is? My dad sold a Toyota hilux to a dealer with over 200k miles on the clock which didn't look or drive like that kind of mileage less than a week later we see it back up for sale with 120k on the clock ![]() 1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
Interesting, I bought a 1996 Defender 90 from a well known independent dealer with 85k on the clock but it was an absolute money pit, had numerous cambelts/mod kits fitted due to eating them, radiator, turbo, clutch and a full engine rebuild. I often wondered if the vehicle had been clocked but had no way of proving it. Won't mention the dealers name but he has been done for it before I later found out!
windymiller Member Since: 03 Oct 2013 Location: farnham Posts: 223 ![]() ![]() |
1999 ..
![]() Click image to enlarge 90 144k apart from a new radiator clutch last year and general wear bit never a problem full service is the key i think ,and it has been to wales landed many times stage 2 Alive tuned as well ,some are just lucky ones i guess. |
