Home > Maintenance & Modifications > Fine bush scratches on 110
Ian Mac
2008 Defender 110 Puma 2.4 XS CSW Java Black
I have recently gone green lanning with my black 110 Xs and it s paint work was 110% mint and very glossy
I have got fine scratches down the sides but then have just damaged the lacquer and left Matt effect scratches on the glossy coat
Paint is not damage but oh can I get theses out to restore
Ian 2008 TDCI 110 XS
1985 90 300tdi. Gone
2005 RR vogue TD6. Gone
Post #291045 17th Dec 2013 10:23am
Mine has the same but faint. Sad
Post #291046 17th Dec 2013 10:32am
Cheshire110
First try some good wax (turtle wax etc)
If that doesn't do it, try a gentle T-Cut?
I've found that a coat of wax before going out helps no-end and seems to protect the bodywork. Cheers, David
Post #291048 17th Dec 2013 10:40am
Ian Mac
It was pretty well coated in autogym super resin polish before hand and I have tried using that but I still can see them Sad Sad
Post #291051 17th Dec 2013 10:51am
mk1collector
Polish is not the same as wax
Post #291055 17th Dec 2013 11:02am
GUM97
Polish tries to get rid of imperfections, wax does not. An engine to TDi for!
Post #291061 17th Dec 2013 11:15am
How about a fine lacquer pen? Something that is cleaned and adds the thinnest layer of Lear over it. I.e, LR's stupid touch up things are useless.
Post #291062 17th Dec 2013 11:19am
jimbob7
You need a proper cutting polish, AGR is more filler than polish,T-cut is good if you have some in the garage or try Farecla G3 Formula ( Halfords) or Meguiars Ultimate compound,to get the best finish you need to buy some micro fibre cloths (Asda Ł4 fer 6).You should also finish off with wax.Then dont go green laning otherwise your pi**in in the wind Thumbs Up . Pov.spec,ftw. 2006, 110,TD5.
Post #291063 17th Dec 2013 11:28am
Have a look at http://www.theultimatefinish.co.uk/
There are various anti-scratch / anti-swirl compounds available - you should be able to recover your paintwork, if you are not sure, they are very helpful on the phone lines
Post #291066 17th Dec 2013 11:42am
Ian Mac
Nice site... I did not know there were so many products available. I'm not going green leaning it it no more so will want it looking its best. Is it best to hire a pro to do this compound paste method?
Post #291067 17th Dec 2013 11:52am
jimbob7
You can get good results by hand but it will take a while.If you wanna get ocd about it go over to Detailing World.
This is mine after a full machine polish (by me),it was originally ex Forestry Commission so you can imagine the scratches on it, does need looking after,but it keeps me outta trouble,lol.
[/img] Pov.spec,ftw. 2006, 110,TD5.
Post #291076 17th Dec 2013 12:24pm
Katoom
Maybe take the 110 to a local body/paint shop and seek advice.
I took in a Rover 75 I was selling which had scratches through the lacquer. 15 minutes later the effected panels were transformed without any hint of damage. Apart from being cheaper than buying compounds, polishes, tools etc etc. it took the stress away of possibly making things worse had I attempted diy.
Post #291080 17th Dec 2013 12:46pm
Katoom
Post #291083 17th Dec 2013 12:51pm
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
+1 for Meguiars Ultimate Compound. It works really well, and is not too harsh on the paintwork
Post #291125 17th Dec 2013 3:54pm
How does this compound stuff work?
Post #291131 17th Dec 2013 4:16pm
