![]() | Home > Maintenance & Modifications > Fine bush scratches on 110 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Mine has the same but faint.
![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
First try some good wax (turtle wax etc)
If that doesn't do it, try a gentle T-Cut? I've found that a coat of wax before going out helps no-end and seems to protect the bodywork. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Ian Mac Member Since: 16 Oct 2013 Location: Essex Posts: 53 ![]() ![]() |
It was pretty well coated in autogym super resin polish before hand and I have tried using that but I still can see them
![]() ![]() Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
Polish is not the same as wax
Polish tries to get rid of imperfections, wax does not. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
How about a fine lacquer pen? Something that is cleaned and adds the thinnest layer of Lear over it. I.e, LR's stupid touch up things are useless. Chillin In The Backwoods🇬🇧🇺🇸
You need a proper cutting polish, AGR is more filler than polish,T-cut is good if you have some in the garage or try Farecla G3 Formula ( Halfords) or Meguiars Ultimate compound,to get the best finish you need to buy some micro fibre cloths (Asda £4 fer 6).You should also finish off with wax.Then dont go green laning otherwise your pi**in in the wind
Have a look at http://www.theultimatefinish.co.uk/
There are various anti-scratch / anti-swirl compounds available - you should be able to recover your paintwork, if you are not sure, they are very helpful on the phone lines |
Nice site... I did not know there were so many products available. I'm not going green leaning it it no more so will want it looking its best. Is it best to hire a pro to do this compound paste method?
You can get good results by hand but it will take a while.If you wanna get ocd about it go over to Detailing World.
This is mine after a full machine polish (by me),it was originally ex Forestry Commission so you can imagine the scratches on it, does need looking after,but it keeps me outta trouble,lol. ![]() Click image to enlarge[/img] Pov.spec,ftw. 2006, 110,TD5. |
Katoom Member Since: 07 Dec 2013 Location: Devon Posts: 25 ![]() ![]() |
Maybe take the 110 to a local body/paint shop and seek advice.
I took in a Rover 75 I was selling which had scratches through the lacquer. 15 minutes later the effected panels were transformed without any hint of damage. Apart from being cheaper than buying compounds, polishes, tools etc etc. it took the stress away of possibly making things worse had I attempted diy. |
AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116 ![]() ![]() ![]() |
+1 for Meguiars Ultimate Compound. It works really well, and is not too harsh on the paintwork
How does this compound stuff work? Chillin In The Backwoods🇬🇧🇺🇸
