Home > Maintenance & Modifications > Fine bush scratches on 110 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20355 |
Mine has the same but faint. $W33T $0U7H3RN $UG4R
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
17th Dec 2013 10:32am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2754 |
First try some good wax (turtle wax etc)
If that doesn't do it, try a gentle T-Cut? I've found that a coat of wax before going out helps no-end and seems to protect the bodywork. Cheers, David Land Rovers of all shapes S3 onwardsโฆ Daily is a 110 V8. |
17th Dec 2013 10:40am |
Ian Mac Member Since: 16 Oct 2013 Location: Essex Posts: 53 |
It was pretty well coated in autogym super resin polish before hand and I have tried using that but I still can see them
Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
17th Dec 2013 10:51am |
Polish is not the same as wax
17th Dec 2013 11:02am |
Polish tries to get rid of imperfections, wax does not. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
17th Dec 2013 11:15am |
How about a fine lacquer pen? Something that is cleaned and adds the thinnest layer of Lear over it. I.e, LR's stupid touch up things are useless. $W33T $0U7H3RN $UG4R
17th Dec 2013 11:19am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
You need a proper cutting polish, AGR is more filler than polish,T-cut is good if you have some in the garage or try Farecla G3 Formula ( Halfords) or Meguiars Ultimate compound,to get the best finish you need to buy some micro fibre cloths (Asda ฃ4 fer 6).You should also finish off with wax.Then dont go green laning otherwise your pi**in in the wind . Pov.spec,ftw. 2006, 110,TD5.
17th Dec 2013 11:28am |
Have a look at http://www.theultimatefinish.co.uk/
There are various anti-scratch / anti-swirl compounds available - you should be able to recover your paintwork, if you are not sure, they are very helpful on the phone lines |
17th Dec 2013 11:42am |
Nice site... I did not know there were so many products available. I'm not going green leaning it it no more so will want it looking its best. Is it best to hire a pro to do this compound paste method?
17th Dec 2013 11:52am |
You can get good results by hand but it will take a while.If you wanna get ocd about it go over to Detailing World.
This is mine after a full machine polish (by me),it was originally ex Forestry Commission so you can imagine the scratches on it, does need looking after,but it keeps me outta trouble,lol. Click image to enlarge[/img] Pov.spec,ftw. 2006, 110,TD5. |
17th Dec 2013 12:24pm |
Katoom Member Since: 07 Dec 2013 Location: Devon Posts: 25 |
Maybe take the 110 to a local body/paint shop and seek advice.
I took in a Rover 75 I was selling which had scratches through the lacquer. 15 minutes later the effected panels were transformed without any hint of damage. Apart from being cheaper than buying compounds, polishes, tools etc etc. it took the stress away of possibly making things worse had I attempted diy. |
17th Dec 2013 12:46pm |
17th Dec 2013 12:51pm |
AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116 |
+1 for Meguiars Ultimate Compound. It works really well, and is not too harsh on the paintwork
17th Dec 2013 3:54pm |
How does this compound stuff work? $W33T $0U7H3RN $UG4R
17th Dec 2013 4:16pm |
