Home > Td5 > Warm up in cold weather
Page 1 of 3 123>
ibexman
I took off the grill and blanked off the rad under the inter cooler on my td5
:and it made not one bit of difference to warm up time Whistle
Post #289225 10th Dec 2013 6:19pm
grafty99
The bottom of the radiator doesn't do a huge amount of cooling I don't think, for best results try a bit of cardboard between the inter cooler and rad at the top, I believe the top is where most of the cooling happens Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #289246 10th Dec 2013 7:15pm
VeeTee
Netherlands
Makes sense: when the engine is cold, the thermosthat is closed and there is no flow of cooling fluid through the radiator.
Therefore warming up time from cold engine is not much influenced.
Only after the engine is at working temperature, it easier to maintain the temperature because of less heat loss through the engine compartment and radiator by restricted air flow. Cheers, Vincent
MySite
Post #289266 10th Dec 2013 8:00pm
geobloke
Have you taken your viscous fan off yet? Once a long time ago in an atempt to make my 200tdi 90 warm up quicker I made a rad muff, took the fan off and sealed up the gaps between the bonnet and the wings with old door seals. Think it helped a bit, but not worth the effort.
Post #289271 10th Dec 2013 8:15pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I don't think TD5s work too well with no fan. The old TDIs were ok, but TD5...not such a great idea. 1998 110 300Tdi White Hard Top
Post #289275 10th Dec 2013 8:26pm
Lou Sparts
I have thought about lagging the heater box under the bonnet to stop it being blasted with cold air.Anyone tried it ? 2005 Td5 90 XS
Steve
Post #289277 10th Dec 2013 8:30pm
excossack
Have you been reading my mind? I was changing the oil at the weekend and was looking at the heater box and pipes thinking - pipe lagging and foam coat for the heater box. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #289286 10th Dec 2013 8:57pm
Lou Sparts
Haha great minds think alike Thumbs Up 2005 Td5 90 XS
Steve
Post #289287 10th Dec 2013 9:00pm
Laurie
My TD5 Ninety XS takes about five miles to warm up in winter.
In summer, with the caravan on a motorway it keeps going into limp mode from overheating.
If you've got air-con the radiator's right on the limit of capacity.
Post #289298 10th Dec 2013 9:22pm
Laurie, that sounds like you've got a problem, to be honest. I tow a big twin axle 'van with my 110 XS and even with four bikes on the roof there isn't a hint of overheating. Mine also takes longer than five minutes to warm up, too. Darren
Post #289301 10th Dec 2013 9:35pm
Laurie
I said 5 miles not minutes.
It only blips into limp mode. Just lifting off the throttle momentarily resets it.
I've checked the temperature at which it limps. It's 105c.
I've owned it from 6,700 miles and it's now around 70,000.
Post #289304 10th Dec 2013 9:40pm
landy andy
Agree with LRA, never had overheating issue with my Td5 with aircon.
Andy
Post #289306 10th Dec 2013 9:40pm
Sorry, my mistake. Nevertheless, it shouldn't go into limp mode just towing a caravan. Darren
Post #289313 10th Dec 2013 9:51pm
Lou Sparts
Its my understanding that the electric fan in front of the radiators of A/C models is supposed to cut in at 28 degrees ambient temperature to assist cooling. 2005 Td5 90 XS
Steve
Post #289318 10th Dec 2013 10:03pm
Laurie
I do really use mine.
It does some serious offroading.
It started happening after driving through a load of gloop.
Having given the radiator a thorough cleaning it almost stopped.
It is very difficult to clean the rad properly on an XS.
Post #289320 10th Dec 2013 10:06pm
Page 1 of 3 123>
