![]() | Home > Wheels & Tyres > Puma OE Alloy wheel nut replacements |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 745 ![]() ![]() ![]() |
I actually like the sound of them lasting forever so when a friend of mine sold his last set to someone else, I decided to get the solid ones from another friend.
I guess this means I should already be changing them out, huh? |
as said the old style ones did last , but rusted on the edges when used and didn't look as pretty as the later stainless covered ones
Hmm... We just can't win, can we?
Lesser of two evils then? |
old style + eBay item number:
eBay Item No. 281294529647 not the best solution ![]() |
Voila! How deep are your pockets? http://www.wrington.co.uk/index.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
See Tiger Spots change nah
Interesting solutions, but I think I can categorize those under "nice to have" rather than "must have." Nice to know they're out there though.
Thanks! |
I've actually been mulling it over last night and am thinking that since I already have the solid wheel nuts that I should use them first and while they are on, I should already start saving up of the wrington ones for when the said corrosion appears.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2652 ![]() ![]() ![]() |
Sjoe, expensive! Any other uncapped wheel nut providers out there? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1948 ![]() ![]() ![]() |
Now you have said it......i removed both front wheels yesterday to fit my new LOF brakes kit
![]() And upon putting the wheels back on the nuts did struggle to go in the socket and i remember them being a bit looser when removed.....so yes nuts do swell ![]() ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
