Home > Wheels & Tyres > Puma OE Alloy wheel nut replacements
Page 2 of 2 <12
munch90
the old classic range rover vogue nuts were solid and did last for ever , but rusted when bruised on the edges by a socket
stainless covered ones swell due to rust between the cover and the nuts steel inside , new they are 27mm ( 1.1/16 af size ), swollen 28mm will work but after a while the stainless cover can work lose and come off and get stuck in the socket ( hard to remove at roadside ), then with no stainless cover you need a 26mm socket ( not a common size )
rust proofed mine always and never had a problem
Post #436819 10th Jul 2015 7:04am
HardCharger
I actually like the sound of them lasting forever so when a friend of mine sold his last set to someone else, I decided to get the solid ones from another friend.
I guess this means I should already be changing them out, huh?
Post #436826 10th Jul 2015 7:22am
munch90
as said the old style ones did last , but rusted on the edges when used and didn't look as pretty as the later stainless covered ones
Post #436827 10th Jul 2015 7:28am
HardCharger
Hmm... We just can't win, can we?
Lesser of two evils then?
Post #436828 10th Jul 2015 7:32am
munch90
old style + eBay item number:
eBay Item No. 281294529647
not the best solution Laughing
Post #436829 10th Jul 2015 7:37am
K9F
ken wrote:
OEM Nut is 27mm the 28mm is a get around
Just buy new 27mm nuts I'm sure Mal (K9) will provide the relevant link to a great aftermarket supplier
Voila! How deep are your pockets?
http://www.wrington.co.uk/index.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436831 10th Jul 2015 7:47am
See Tiger Spots change nah Rolling with laughter
Post #436838 10th Jul 2015 8:16am
HardCharger
Interesting solutions, but I think I can categorize those under "nice to have" rather than "must have." Nice to know they're out there though.
Thanks!
Post #436841 10th Jul 2015 8:23am
HardCharger
I've actually been mulling it over last night and am thinking that since I already have the solid wheel nuts that I should use them first and while they are on, I should already start saving up of the wrington ones for when the said corrosion appears.
Post #437013 11th Jul 2015 4:47am
Naks
Sjoe, expensive!
Any other uncapped wheel nut providers out there? --
Post #827712 26th Apr 2020 7:42am
bear100
Now you have said it......i removed both front wheels yesterday to fit my new LOF brakes kit Very Happy
And upon putting the wheels back on the nuts did struggle to go in the socket and i remember them being a bit looser when removed.....so yes nuts do swell Embarassed Shocked Rolling with laughter 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #827714 26th Apr 2020 7:58am
Page 2 of 2 <12
