Home > Puma (Tdci) > Oil filter plastic cup, stuck. How to get it off? |
rasmussen Member Since: 13 Mar 2012 Location: Nice Posts: 46 |
I have been searching here on the forum to see if there have been other like me who cannot get the oil filter plastic cup off.
But I seem to be the only useless chap here Basically I have just drain the oil from the warm engine but now I cannot get the filter cup off. The plastic edges on the “nut” is getting worth and worth. I really try to push hard as I can upwards while turn but no luck. Is there anyone who know of a trick? All advise would be appreciated. Thank you, |
31st Aug 2013 10:34am |
mega Member Since: 23 Oct 2010 Location: notts Posts: 33 |
Hi its better if you use a 6 sided socket and not the 12 point type
31st Aug 2013 2:24pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Yep def 6 side socket
27mm if I am correct. Same size as your wheel nuts Put some grease on the threads when you refit / replace it Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
31st Aug 2013 7:16pm |
Gents,
Thank you very much for your replies!!! I still have a lot to learn! Cheers, |
4th Sep 2013 5:37pm |
Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Sep 2013 6:29pm |
Take it I am right Chris
5th Sep 2013 6:08pm |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 |
And keep in mind: Torque is 25Nm/19ft.lbs !
Cheers Det locker bleiben |
6th Sep 2013 5:55am |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 |
Hi Folks,
I have the correct 27mm spanner to remove my oil filter housing but cannot budge it, presumably because the main dealer that last serviced it did it up too tight? If I try too hard it looks like the plastic housing will twist and break. Does anybody have any tips that will make it easier to remove? Untried thoughts are: surround it with a pot of boiling water to heat up the plastic, or run engine to warm things up from the inside, both hoping the plastic will expand slightly more than the aluminium engine and thus become easier to remove. All ideas welcome, thanks. 2.2 90 XS 88" Series One Old Norton Minerva |
7th Dec 2016 11:01am |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
.....belt type oil filter remover? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
7th Dec 2016 1:09pm |
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 |
Get one of these six sided, face drive sockets.
http://www.ebay.co.uk/itm/NEW-Genuine-LASE...SwAuZX1Upk http://www.ebay.co.uk/itm/Sealey-WallDrive...Sw4SlV8X-Y |
7th Dec 2016 5:13pm |
or use wheel nut brace its 6 sided and 27mm
7th Dec 2016 5:16pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
Order a new one whatever.
But yeah I'm with the strap wrench folk on this one... It's exactly for this situation. Solved the bowel problem, working on the consonants... |
7th Dec 2016 6:05pm |
LR004508
7th Dec 2016 6:09pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
buy the new one and have it ready before you try again, the one you have will need replacing and may well fail as you remove it and you will then be stuck DEFENDER 90 TDCI XS,
7th Dec 2016 6:24pm |
