Home > Td5 > Brake vacuum pump....repair?
Anyone had any luck trying to repair the Td5 vauum pump? mine seems to be giving a similar amount of "suck" compared to another td5 parked along side, but when you start the engine with your foot on the brake pedal, it doesn't move down.
I've swapped the servo for a working one (took it off of another vehicle) and still the same (and refitted the original servo from my 110 onto the other vehicle, and it's working a treat)
Or anyone got an old duff Td5 alternator with a good pump on it?
Post #261910 28th Aug 2013 3:26pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Have you checked all the pipe work for chaffing, splits or kinks? We have a few problems on the vans at work!
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #261930 28th Aug 2013 5:43pm
Yeah, that was the first thing I did, AOK.
It's giving some suction, but i's quite "noisy", you hear a chuf chuf chuf from the pipe, where my other Td5 is more continous and much quieter.
Also, when I removed the pump from the front of the alternator (as a side note, this is really easy... disconnect the pipes, oil feed and drain, and obviously the vacuum pipe itself, then undo the 4x 10mm bolts, and the pump bit pulls off of the alternator, so no need to disconnect the battery or anything like that) there was some oil in there, about a thimble full drained out. Don't know if some residual leakage is acceptable, or if it shows that the innards of the vac pump are well and truly on their way out.
Post #261942 28th Aug 2013 6:32pm
just picked up a used pump, so will get it cleaned up and fitted and see what happens!
Post #262363 30th Aug 2013 9:52am
