Home > Td5 > Brake vacuum pump....repair? |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 558 |
Have you checked all the pipe work for chaffing, splits or kinks? We have a few problems on the vans at work!
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
28th Aug 2013 5:43pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Yeah, that was the first thing I did, AOK.
It's giving some suction, but i's quite "noisy", you hear a chuf chuf chuf from the pipe, where my other Td5 is more continous and much quieter. Also, when I removed the pump from the front of the alternator (as a side note, this is really easy... disconnect the pipes, oil feed and drain, and obviously the vacuum pipe itself, then undo the 4x 10mm bolts, and the pump bit pulls off of the alternator, so no need to disconnect the battery or anything like that) there was some oil in there, about a thimble full drained out. Don't know if some residual leakage is acceptable, or if it shows that the innards of the vac pump are well and truly on their way out. |
28th Aug 2013 6:32pm |
just picked up a used pump, so will get it cleaned up and fitted and see what happens!
30th Aug 2013 9:52am |
