Home > Puma (Tdci) > Cruise Control |
WinBoot Member Since: 09 Jan 2010 Location: Ieper Posts: 28 |
Which kit? Any pics?
19th Feb 2010 4:53pm |
what the price and isnt it possible to use a controller like the one for side indicators? Ive seen something like that around, forgot where it was tough |
19th Feb 2010 5:21pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
The reason im using this controller is
1 Its very easy to reach and use in the position shown 2 Its easy to fit and connect where shown 3 There is no easy way to fit a column mounted stalk due to the flimsy plastic LR use for the cowling Option 1 Kit only supplied with detailed fitting instructions inc actual photos of where and what to connect £360+Vat+Delivered in UK Option 2 Supplied and Fitted near Gloucester £460+vat |
19th Feb 2010 5:43pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Winboot,,, see you are in Ieper,, if you want one of Sonic's kits, i can bring it over in June for you,, Coming over to do the rally Sonic PM on the way California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
20th Feb 2010 8:33pm |
Ill take it in consideration, still looking for some options
21st Feb 2010 1:10pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Any chance of you doing a post 2002 TD5 CC kit sonic?
21st Feb 2010 11:27pm |
For TD5 is VERY easy to build 4 wires and two buttons
he pins on the ECU will be connected the following way: Pin 10 - ignition +12V Pin 11 - switch 1 (set function) Pin 15 - ignition +12V Pin 17 - switch 2 (resume function) Pin 19 - is only mentioned, that you can connect here the available TD5 tachometer, not used for the cruise control So the cruise control works by supplying ignition +12V to pin 10/15 permanently and the functions are activated by supplying the same temporary to pin 11 or 17. (thanks to Pete Bell) For getting the ignition switched +12V (Zuendplus Klemme 15), if I remember correctly, when I had last time my dash off, use the green/white cable at the temperature or fuel gauge in the dash. Put two switches on the dash and run a long cable to the ECU. RS Components part # 362-9367 for the ECU (big) terminals) RS Components part # 314-1340 for defender switches More details: http://trt.net.au/files/TD5Cruise.pdf http://trt.net.au/files/TRTDefenderTD5Cruise.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd Feb 2010 8:06am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
Hi guys,
I go the following reply from Steve @ Conrad-Anderson: We do have a cruise kit for the new Ford engined Defender however it is not a straightforward plug in to the pedal. When fitting, you will need to splice/solder in the pedal adaptor to the original loom. Please see attached the schematic wiring and page 27 of the install manual gives you more specific wiring for the pedal. AP800 Electronic Kit £238.30 CM7 Dash Pad command module £31.91 GCT240 Universal T harness £38.30 Carriage to SA £50 Links to the manual & wiring diagram: https://docs.google.com/leaf?id=0B0DKxtjT2...&hl=en https://docs.google.com/fileview?id=0B0DKx...&hl=en Looks a bit steep for my pocket though |
28th Feb 2010 7:29am |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 |
just ordered my kit from sonic , can't wait.... Cheers
keith puer claudius |
11th Mar 2010 7:46pm |
sonic
Sent a pm with a few questions about installation and asked for any detailed pictures, any chance you respond. Cheers keith puer claudius |
17th Mar 2010 8:16am |
heinrichnel Member Since: 07 Apr 2010 Location: Windhoek, Namibia Posts: 42 |
Has anyone managed to find out anything more about the terrafirma cruise control? I emailed 3 different suppliers of terrafrima goods in South Africa and was met with total silence. Funny how if you want to spend money no one wants it????
13th Apr 2010 10:53pm |
Heinrich, you will probably get more info from Terrafirma themselves! |
14th Apr 2010 5:49am |
Forget Terrafirma buy mine Could be posted this week |
14th Apr 2010 10:35am |
Sonic, how about some pics of the installation and the kit, diagram of the setup and some prices? or even better, a YouTube clip of the installation? |
14th Apr 2010 10:42am |
