![]() | Home > Puma (Tdci) > Cruise Control |
munsterlandy Member Since: 17 Dec 2009 Location: munster Posts: 52 ![]() ![]() ![]() |
sonic3d
any update on cruise ? ![]() ![]() |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Interest registered! is it a simple to use system? how is it controlled? and does it require any wire hacking / modification?
i don't think you'll have much trouble drumming up interest
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
It very simple to install and calibrate, it is controlled by a small control pad that is best mounted on the flat surface to the side of the radio/heater controls.
It needs an analogue can bus signal for the speed sensor - taken from the rear of the dash A wire to the clutch switch on the pedal box under the bonnet A wire to the brake switch on the pedal Power and earth |
looking forward to pm
Interested dependant on costings! If you go through life with your head in the sand....all people will see is an ar5e!!
me too Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
BBSJK Member Since: 12 Sep 2009 Location: Ledbury, Herefs Posts: 100 ![]() ![]() ![]() |
I'd be interested, depending on the pennies. It's the only thing I miss from the 'normal' car when I'm in the Landy. No the other left . . .
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
I am also interested Sonic!
![]() Apparently the firm that supplies Terrafirma's cruise control has gone bust! |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2668 ![]() ![]() ![]() |
Read on an Aussie LR forum that this Waeco unit is compatible with the Freelander 2, which may mean it is compatible with the Puma as well:
http://www.waeco.com/en/3512_1340.php http://www.waeco.com/en/4374_1340.php?artOrigID=35503&sprID=2 |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
so, this may be a dumb question, but can it be fitted to a puma based 90? and does it plug into the port under steering wheel?
but most of all. how much and when can i get one? Cheers keith puer claudius |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 ![]() ![]() ![]() |
This unit is compatible with Ford Transit (2.4TDCi Engine), so I assumed it would be applicable to the Defender. I tried to get an answer out of WAECO on this, and was met with silence. Perhaps they don't ship to AUS, and that's why they ignored me. |
If it is compatible with the Ford Transit, then it "must" be compatible with the Puma. After all, both use the Ford CANBus, but do they use the same ECU? |
