Home > Puma (Tdci) > Cruise Control
Page 4 of 5 <12345>
WinBoot
Belgium
Which kit? Any pics?
Post #24679 19th Feb 2010 5:53pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
My Kit Very Happy
There is a pic of the control pad earlier in the post Thumbs Up as for the rest of it as i said earlier its 2 small boxes that are hidden behind the dash Thumbs Up
Post #24680 19th Feb 2010 6:16pm
WinBoot
Belgium
Sonic3d wrote:
My Kit Very Happy
what the price and isnt it possible to use a controller like the one for side indicators?
Ive seen something like that around, forgot where it was tough
Post #24681 19th Feb 2010 6:21pm
Sonic3d
The reason im using this controller is
1 Its very easy to reach and use in the position shown
2 Its easy to fit and connect where shown
3 There is no easy way to fit a column mounted stalk due to the flimsy plastic LR use for the cowling
Option 1 Kit only supplied with detailed fitting instructions inc actual photos of where and what to connect
�360+Vat+Delivered in UK
Option 2 Supplied and Fitted near Gloucester �460+vat
Post #24682 19th Feb 2010 6:43pm
TJ101
WinBoot wrote:
Sonic3d wrote:
My Kit Very Happy
Winboot,,, see you are in Ieper,, if you want one of Sonic's kits, i can bring it over in June for you,,
Coming over to do the rally Thumbs Up
Sonic PM on the way Very Happy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #24745 20th Feb 2010 9:33pm
WinBoot
Belgium
Ill take it in consideration, still looking for some options Wink
Post #24778 21st Feb 2010 2:10pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Any chance of you doing a post 2002 TD5 CC kit sonic?
Post #24811 22nd Feb 2010 12:27am
dgardel
Italy
For TD5 is VERY easy to build 4 wires and two buttons
he pins on the ECU will be connected the following way:
Pin 10 - ignition +12V
Pin 11 - switch 1 (set function)
Pin 15 - ignition +12V
Pin 17 - switch 2 (resume function)
Pin 19 - is only mentioned, that you can connect here the available TD5 tachometer, not used for the cruise control
So the cruise control works by supplying ignition +12V to pin 10/15 permanently and the functions are activated by supplying the same temporary to pin 11 or 17.
(thanks to Pete Bell)
For getting the ignition switched +12V (Zuendplus Klemme 15), if I remember correctly, when I had last time my dash off, use the green/white cable at the temperature or fuel gauge in the dash. Put two switches on the dash and run a long cable to the ECU.
RS Components part # 362-9367 for the ECU (big) terminals)
RS Components part # 314-1340 for defender switches
More details:
http://trt.net.au/files/TD5Cruise.pdf
http://trt.net.au/files/TRTDefenderTD5Cruise.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #24818 22nd Feb 2010 9:06am
Naks
Hi guys,
I go the following reply from Steve @ Conrad-Anderson:
We do have a cruise kit for the new Ford engined Defender however it is not a straightforward plug in to the pedal. When fitting, you will need to splice/solder in the pedal adaptor to the original loom.
Please see attached the schematic wiring and page 27 of the install manual gives you more specific wiring for the pedal.
AP800 Electronic Kit �238.30
CM7 Dash Pad command module �31.91
GCT240 Universal T harness �38.30
Carriage to SA �50
Links to the manual & wiring diagram:
https://docs.google.com/leaf?id=0B0DKxtjT2...&hl=en
https://docs.google.com/fileview?id=0B0DKx...&hl=en
Looks a bit steep for my pocket though Sad
Post #25352 28th Feb 2010 8:29am
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
just ordered my kit from sonic Bow down , can't wait.... Very Happy Cheers
keith
puer claudius
Post #26552 11th Mar 2010 8:46pm
kljw
cruise control
sonic
Sent a pm with a few questions about installation and asked for any detailed pictures, any chance you respond. Cheers
keith
puer claudius
Post #27140 17th Mar 2010 9:16am
heinrichnel
Namibia 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
cruise control
Has anyone managed to find out anything more about the terrafirma cruise control? I emailed 3 different suppliers of terrafrima goods in South Africa and was met with total silence. Funny how if you want to spend money no one wants it????
Post #29759 13th Apr 2010 11:53pm
Naks
Re: cruise control
Heinrich, you will probably get more info from Terrafirma themselves!
Post #29770 14th Apr 2010 6:49am
Sonic3d
Re: cruise control
Forget Terrafirma buy mine Could be posted this week Whistle
Post #29794 14th Apr 2010 11:35am
Naks
Re: cruise control
Sonic, how about some pics of the installation and the kit, diagram of the setup and some prices?
or even better, a YouTube clip of the installation? Wink
Post #29795 14th Apr 2010 11:42am
Page 4 of 5 <12345>
