Home > Td5 > Def unlocking itself |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3372 |
Taffrican, I had the same thing with the 110 and it was one of the servos in the door was kaput.
16th Aug 2013 7:32am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5690 |
Had this with mine was the central locking actuator in the drivers door. About £20 ish from main dealer.
Andy |
16th Aug 2013 7:52am |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
Thanks for the tips guys, never dealt with one before, how do you go about testing to find out which one?
Interestingly a few weeks ago the passenger door stopped locking when I locked drivers side from inside Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
16th Aug 2013 8:02am |
It'll be the drivers door one, as that's the one that triggers the alarm. Darren
16th Aug 2013 8:14am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17363 |
I would have though that it is most likely to be the driver's door actuator, since this is the only one which will cause all the others to unlock.
If you can access the connectors in the door pillars and disconnect the other doors one at a time that should tell you. With the connectors apart, the door will neither lock nor unlock centrally. It sounds to me as though the driver's door is mislocking and therefore unlocking itself, and since it controls the others, they are all doing this. I don't see why this is causing the alarm to go off though. Could it be that a door switch (interior light/alarm switch) is faulty and the 10AS thinks that a door is open? I would have though that that would cause a mislock, though, and not let the car lock, you walk away, and then unlock. If you get in and shut the door, does the interior light turn off as usual (if so it suggests that the door switches are OK)? (Editted for spelling). |
16th Aug 2013 8:18am |
Thanks for that Darren & BW, yes the lights go off as normal so I think you are right about the drivers door actuator, I've ordered one from craddocks, hopefully that will be the end of this chapter in my LR education Optimists say the glass is half full..
16th Aug 2013 8:59am |
bought new actuator for drivers side door and fitted, all appeared good until I get to work again tonight and lock the 90 then it all kicked off again, exactly the same as before, door just keeps on unlocking itself, where to now chaps (just ordered a nanocom from BBS, maybe that will help, but that probably wont be here til next week) so need tips ASAP pls guys Optimists say the glass is half full..
22nd Aug 2013 8:06pm |
Take out the drivers door lock mech and give it a very thorough clean up and wd40 then when you put it back together make sure all the rods are free moving
22nd Aug 2013 8:16pm |
cheers mk, i'll give it a try Optimists say the glass is half full..
22nd Aug 2013 10:46pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I had a similar problem a while back. On mine it was caused by the driver's side door not quite being fully on the second catch. I ended up adjusting the striker slightly so that the lock was fully engaged and that fixed it. http://www.yorkshireoffroadclub.net/
22nd Aug 2013 11:53pm |
cheers Dave, I'll be looking at that too Optimists say the glass is half full..
23rd Aug 2013 2:33am |
Lordsmut Member Since: 28 Nov 2015 Location: Bucks Posts: 23 |
I know it’s been a while, but how did you get on? I’ve got the same thing
Cheers |
27th Aug 2018 7:06pm |
I found a screw had gone through the alarm loom, it was my own fault, I put new speakers in the front and I had to fit longer screws and one of them cut the wiring, you could hardly see it with the eye but it caused all kinds of havoc. Optimists say the glass is half full..
27th Aug 2018 7:26pm |
Ahh. Glad you sussed it, I’ll have to investigate further
27th Aug 2018 7:35pm |
