Home > Td5 > Def unlocking itself
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Hi Chaps, I done a search on this topic but only came up with one thread which didn't really help much.
This morning when I got to work I locked the 90 with the zapper and walked away, next thing I heard the door unlock and alarm went off, I thought I must have triggered the zapper by mistake so I locked it again and paid special attention to not trigger the zapper again, same thing, doors unlocked and alarm went off Shocked ... so I proceeded to lock all doors with the key and look at it later...no problem until I locked the drivers door...then about 2 sec after locking the drivers door it just popped open again and alarm went off again, done this a few times until it eventually latched and I was able to walk away, I don't think it will come right by itself, any ideas?
cheers Bow down Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #259049 16th Aug 2013 7:02am
camelman
Taffrican, I had the same thing with the 110 and it was one of the servos in the door was kaput.
Post #259053 16th Aug 2013 7:32am
landy andy
Had this with mine was the central locking actuator in the drivers door. About £20 ish from main dealer.
Andy
Post #259059 16th Aug 2013 7:52am
taffrican
Thanks for the tips guys, never dealt with one before, how do you go about testing to find out which one?
Interestingly a few weeks ago the passenger door stopped locking when I locked drivers side from inside Shocked Optimists say the glass is half full..
Post #259061 16th Aug 2013 8:02am
It'll be the drivers door one, as that's the one that triggers the alarm. Darren
Post #259066 16th Aug 2013 8:14am
I would have though that it is most likely to be the driver's door actuator, since this is the only one which will cause all the others to unlock.
If you can access the connectors in the door pillars and disconnect the other doors one at a time that should tell you. With the connectors apart, the door will neither lock nor unlock centrally.
It sounds to me as though the driver's door is mislocking and therefore unlocking itself, and since it controls the others, they are all doing this. I don't see why this is causing the alarm to go off though. Could it be that a door switch (interior light/alarm switch) is faulty and the 10AS thinks that a door is open? I would have though that that would cause a mislock, though, and not let the car lock, you walk away, and then unlock.
If you get in and shut the door, does the interior light turn off as usual (if so it suggests that the door switches are OK)?
(Editted for spelling).
Post #259068 16th Aug 2013 8:18am
taffrican
Thanks for that Darren & BW, yes the lights go off as normal so I think you are right about the drivers door actuator, I've ordered one from craddocks, hopefully that will be the end of this chapter in my LR education Thumbs Up Optimists say the glass is half full..
Post #259078 16th Aug 2013 8:59am
taffrican
Big Cry bought new actuator for drivers side door and fitted, all appeared good until I get to work again tonight and lock the 90 Big Cry then it all kicked off again, exactly the same as before, door just keeps on unlocking itself, where to now chaps (just ordered a nanocom from BBS, maybe that will help, but that probably wont be here til next week) so need tips ASAP pls guys Bow down Optimists say the glass is half full..
Post #260668 22nd Aug 2013 8:06pm
mk1collector
Take out the drivers door lock mech and give it a very thorough clean up and wd40 then when you put it back together make sure all the rods are free moving
Post #260674 22nd Aug 2013 8:16pm
taffrican
cheers mk, i'll give it a try Thumbs Up Optimists say the glass is half full..
Post #260742 22nd Aug 2013 10:46pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I had a similar problem a while back. On mine it was caused by the driver's side door not quite being fully on the second catch. I ended up adjusting the striker slightly so that the lock was fully engaged and that fixed it. http://www.yorkshireoffroadclub.net/
Post #260752 22nd Aug 2013 11:53pm
taffrican
Thumbs Up cheers Dave, I'll be looking at that too Thumbs Up Optimists say the glass is half full..
Post #260753 23rd Aug 2013 2:33am
Lordsmut
England 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
I know it’s been a while, but how did you get on? I’ve got the same thing
Post #725689 27th Aug 2018 7:06pm
taffrican
I found a screw had gone through the alarm loom, it was my own fault, I put new speakers in the front and I had to fit longer screws and one of them cut the wiring, you could hardly see it with the eye but it caused all kinds of havoc. Thumbs Up Optimists say the glass is half full..
Post #725692 27th Aug 2018 7:26pm
Lordsmut
Ahh. Glad you sussed it, I’ll have to investigate further
Post #725697 27th Aug 2018 7:35pm
