Home > Td5 > Help! Engine cuts out at full throttle |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
Today, a member of the Swedish LR Club came by and ran a number of diagnostic tests on his computer.
Checked the TPS several times. Tested with MAF disconnected. He did not see anything unusual but downloaded all results for further studies. When I have his results I will let you know. He was going on vaccation so I will go sailing for a week. I am greatful for all suggestions you have come up with so far. /Hans |
12th Aug 2013 8:13pm |
Your previous problem JimboD3 sounds similar to mine. But how did you go about to confirm that it was the ECU? They seems to be very expensive (ebay) so it would be nice to know Before you go ahead...
/Hans |
12th Aug 2013 10:06pm |
JimboD3 Member Since: 09 Apr 2013 Location: Ware, Herts Posts: 55 |
Hans, I tried swapping the throttle pedal, that didn't work - and then Ian (of IRB fame) suggested the ECU........luckily he had a second hand one available. Jim Td5 110 HD Hardtop.......not quite standard |
13th Aug 2013 8:46pm |
Do you have any recommendations where to purchase an ECU from? Used, service exchange or new?
/Hans |
22nd Aug 2013 11:24pm |
I changed the the subject on this thread as the previous symtoms turned out to be totally wrong. Still no solution found...
/Hans |
25th Aug 2013 10:47pm |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 |
Just two other things to try (from my own experience):
1. Run an earth lead direct from the negative terminal on battery to the little stud on the base of the seatbox where the ECU lives. All you need is a length of cable with bare ends trailed across the inside of the cab to begin with. If it works, you can run it then in a permanent route with connectors. This will guarantee a good earth for the ECU. 2. With a not-full fuel tank, take the filler cap off and go for a drive. If that helps, it's a tank venting problem , i.e you depress the throttle, the system demands more fuel quickly but cannot uplift it because air cannot get into the tank. The ECU then says 'yikes', problem. No promises here and your problem may be more sophisticated but these are two very easy, simple things to try. Best of luch, Simon. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
26th Aug 2013 5:35am |
Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100 |
Your age of car will have the double solenoid throttle valve and egr valve.
I would try the tests with the throttle valve forced open as I have seen electrical faults shut the valve and cause engine shutdown. Maybe try running for the test with the intake hose removed so you can see inside the throttle valve, if doing this disconnect the MAF. If the boost sensor is giving false readings it could be an over boost shutdown which will also shut the throttle valve but this would leave a code. |
26th Aug 2013 6:38am |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Hello all, I had a similar problem and it was the fuel pump, its prefilter was all clogged, I open it up cleaned and now its working fine.
The fuel filter was ok, it seems the pump got dirt from bad fuel or long storaged diesel. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
26th Aug 2013 1:10pm |
That would be my next step. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
26th Aug 2013 4:14pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
When you say the engine dies does it stop or does it just lose all power?
Could your waste gate be jammed closed www.td5.org |
26th Aug 2013 4:35pm |
The engine- and pre-heating lights come on and the engine stops. After a few minutes it can be started again but only if the pre heating light is on. I tried the waste gate actuator rod and it moves but is a bit heavy. /Hans |
26th Aug 2013 9:01pm |
Two easy tests that I will carry out tomorrow. Thanks Simon. /Hans |
26th Aug 2013 9:08pm |
Makes sense. Is it difficult to do this? I guess that I have to drop down the fuel tank. /Hans |
26th Aug 2013 9:16pm |
How would fuel starvation light the glow plug light?
I would see what the throttle valve is doing, it's driven by a solenoid which is driven by the ecu as is the glow plug light. It could be a loom issue or even ecu. |
26th Aug 2013 9:41pm |
