Home > Td5 > Help! Engine cuts out at full throttle
Page 5 of 10 <12345678910>
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
Macpaul wrote:
If you were to remove the ECU you would find the numbers on a sticker at the back that Diesel Jim mentions.
You can't see it in situ.
Thanks! I will take it out tomorrow.
/Hans
Post #261752 27th Aug 2013 8:26pm
Splitpin
If the engine light is coming on there should be a code.
Post #261795 27th Aug 2013 10:12pm
HansT
Yes you are right guys. I took out the ECU today and the number is NNN500020.
Running some checks, I noticed that the fuel filter and its bracket became very hot. The engine was running for around 15 minutes at idling speed and I guess the temperature of the filter was 60-70 Centigrades (very hot to touch with your hands). The coolant gauge was just starting to move.
It was the two pipes going forward that became hot. The two pipes aiming rearwards were cold.
Is this normal behavior?
/Hans
Post #262212 29th Aug 2013 5:41pm
bob neville
Fuel filter getting hot on a TD5 is normal Thumbs Up
2013 Defender 90 CSW - sold
Post #262224 29th Aug 2013 6:35pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Yes it is and 70c is about right.
The fuel circulates through galleries in the cylinder head and so picks up heat that way. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #262239 29th Aug 2013 7:37pm
HansT
Thanks Bob.
I also took a video of what is happening. Never tried video and YouTube before so hope it works.
&feature=youtu.be
Hans
Post #262240 29th Aug 2013 7:38pm
Macpaul
See diagram
Post #262243 29th Aug 2013 7:43pm
landy andy
Have you checked your crank sensor? How quick does it restart? What is exhaust doing during running? Smoke? All norm? What's exhaust doing restart, or not restarting?
Andy
Post #262245 29th Aug 2013 7:54pm
HansT
Thanks for the fuel diagram. But I am not sure that I know how it works. Other than the fuel gets hot and is supposed to. Everything was much easier on my old MG TD Crying or Very sad
Hans
Post #262249 29th Aug 2013 8:02pm
HansT
Andy
I have not checked the crank sensor yet. What am I supposed to look for?
After the engine light comes on and it stops it will not start again but cranks fine. I have to switch off and wait for a minute or two so that the glow plug light comes on. Then it will start fine.
If I switch off when it is running normally I do not have to wait for the glow plug light. It will start immediately.
I have not noticed anything unusual with the exhaust at any time. So I have not paid any attention to it.
Hans
Post #262253 29th Aug 2013 8:16pm
Lou Sparts
This sounds very much like a problem we had at work on a Mondeo diesel.
Now i,m no diesel expert and a mondeo and a Td5 are probably very different beasts but i will carry on anyway at the risk of getting shot down in flames by someone with far more knowledge than me.
Said mondeo showed very similar symptoms to the OP,s defender,it would drive o.k until you put it under some load i.e going up an incline with quite a wide throttle opening then it would just stop as if you had switched off the "ignition"
To cut a long story short it turned out to be worn injectors allowing to much fuel to return to the tank resulting in low fuel pressure in the rail but enough to let the engine run.When the engine demanded a lot of fuel the fuel pressure dropped below a pre determined limit (i think about 960 bar) in the rail and the ECU shuts the engine down as it thinks there is a fuel leak. After leaving the car for a few minutes the car would restart with a short amount of cranking and continue until the next large demand for fuel.
We had the injectors rebuilt by a local diesel specialist and the car is now fine. 2005 Td5 90 XS
Steve
Post #262254 29th Aug 2013 8:18pm
landy andy
It being dirty so getting a Censored signal from flywheel. Easy to take out and clean.
Andy
Post #262258 29th Aug 2013 8:22pm
HansT
If you look at my video you may notice that when the rpm is dropping down the Engine get a small "hick-up" at 900 rpm just before reaching idling speed.
It is something that I did not notice before these problems started. Do you think it is relevant?
Hans
Post #262259 29th Aug 2013 8:24pm
landy andy
No, I think mine does this
Andy
Post #262260 29th Aug 2013 8:27pm
Lou Sparts
When you take your foot off the gas the ECU will stop fuel being injected (this is all to do with emissions) until the revs approach tickover and will then will start to inject fuel to prevent a stall.At least thats my understanding of it. 2005 Td5 90 XS
Steve
Post #262263 29th Aug 2013 8:32pm
