Home > Td5 > Help! Engine cuts out at full throttle
Page 3 of 10 <12345678910>
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
Today, a member of the Swedish LR Club came by and ran a number of diagnostic tests on his computer.
Checked the TPS several times. Tested with MAF disconnected. He did not see anything unusual but downloaded all results for further studies. When I have his results I will let you know.
He was going on vaccation so I will go sailing for a week. I am greatful for all suggestions you have come up with so far.
/Hans
Post #258268 12th Aug 2013 8:13pm
JimboD3
United Kingdom 2003 Defender 110 Td5 HT Bonatti Grey
I had a similar problem a while back - although mine cut out (with MIL light coming on), whenever I touched the throttle pedal. The truck would then take a few attempts to restart, but when it started it ran fine - unless I touched the throttle........
I swapped the throttle pedal - made no difference, eventually Ian (IRB) suggested that it could be the ECU - it was, and after fitting a new one I've not had any further problems.
Apparently, the big capacitors on the power supply side of the ECU can develop dry joints......I did take the thing apart with a view to re-soldering the dry joints, but need one of those big magnifying light things to do it, so it's in the 'to do' pile !
Jim Td5 110 HD Hardtop.......not quite standard Smile
Post #258304 12th Aug 2013 9:15pm
HansT
Engine dies at full throttle
Your previous problem JimboD3 sounds similar to mine. But how did you go about to confirm that it was the ECU? They seems to be very expensive (ebay) so it would be nice to know Before you go ahead...
/Hans
Post #258322 12th Aug 2013 10:06pm
JimboD3
Re: Engine dies at full throttle
/Hans
Hans,
I tried swapping the throttle pedal, that didn't work - and then Ian (of IRB fame) suggested the ECU........luckily he had a second hand one available.
Post #258468 13th Aug 2013 8:46pm
HansT
Do you have any recommendations where to purchase an ECU from? Used, service exchange or new?
/Hans
Post #260751 22nd Aug 2013 11:24pm
HansT
I changed the the subject on this thread as the previous symtoms turned out to be totally wrong. Still no solution found...
/Hans
Post #261306 25th Aug 2013 10:47pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Just two other things to try (from my own experience):
1. Run an earth lead direct from the negative terminal on battery to the little stud on the base of the seatbox where the ECU lives. All you need is a length of cable with bare ends trailed across the inside of the cab to begin with. If it works, you can run it then in a permanent route with connectors.
This will guarantee a good earth for the ECU.
2. With a not-full fuel tank, take the filler cap off and go for a drive. If that helps, it's a tank venting problem , i.e you depress the throttle, the system demands more fuel quickly but cannot uplift it because air cannot get into the tank. The ECU then says 'yikes', problem.
No promises here and your problem may be more sophisticated but these are two very easy, simple things to try.
Best of luch,
Simon. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #261316 26th Aug 2013 5:35am
Splitpin
Your age of car will have the double solenoid throttle valve and egr valve.
I would try the tests with the throttle valve forced open as I have seen electrical faults shut the valve and cause engine shutdown.
Maybe try running for the test with the intake hose removed so you can see inside the throttle valve, if doing this disconnect the MAF.
If the boost sensor is giving false readings it could be an over boost shutdown which will also shut the throttle valve but this would leave a code.
Post #261321 26th Aug 2013 6:38am
ajps72
2001 Defender 110 Td5 SW Chawton White
Hello all, I had a similar problem and it was the fuel pump, its prefilter was all clogged, I open it up cleaned and now its working fine.
The fuel filter was ok, it seems the pump got dirt from bad fuel or long storaged diesel. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #261363 26th Aug 2013 1:10pm
Macpaul
That would be my next step. 2003 Td5 110 Hardtop
Post #261403 26th Aug 2013 4:14pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
When you say the engine dies does it stop or does it just lose all power?
Could your waste gate be jammed closed www.td5.org
Post #261407 26th Aug 2013 4:35pm
HansT
The engine- and pre-heating lights come on and the engine stops. After a few minutes it can be started again but only if the pre heating light is on.
I tried the waste gate actuator rod and it moves but is a bit heavy.
/Hans
Post #261496 26th Aug 2013 9:01pm
HansT
Best of luch,
Simon.
Two easy tests that I will carry out tomorrow. Thanks Simon.
/Hans
Post #261501 26th Aug 2013 9:08pm
HansT
Makes sense. Is it difficult to do this? I guess that I have to drop down the fuel tank.
/Hans
Post #261506 26th Aug 2013 9:16pm
Splitpin
How would fuel starvation light the glow plug light?
I would see what the throttle valve is doing, it's driven by a solenoid which is driven by the ecu as is the glow plug light.
It could be a loom issue or even ecu.
Post #261518 26th Aug 2013 9:41pm
