Home > Puma (Tdci) > Puma oil spec?
Page 4 of 5 <12345>
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Naks wrote:
LESVOSD110 wrote:
5w-50 A3/B3/B4 synthetic and changed every 6000km.It handles our heat and no cold start problems.
Can you please specify the API classification and brand? Wink
I don't even look at API as there standards are very low.It's a fuchs oil. Puma 110 SW
90 V8 SOFT TOP
Post #50897 3rd Jan 2011 8:15pm
Naks
dgardel wrote:
Look here: http://www.bobistheoilguy.com/forums/ubbth...amp;page=1 and related
Thanks!
So, what oil do you use? And how does it compare to the Magnatec 5w30?
Post #50898 3rd Jan 2011 8:16pm
LESVOSD110
Naks.
I forgot,what beer do you drink?No imports please. Puma 110 SW
90 V8 SOFT TOP
Post #50899 3rd Jan 2011 8:17pm
dgardel
Italy
Naks wrote:
Thanks!
Castrol Magnatec low HTHS is named Professional A1.
Normal Magnatec is A3/B4 or only c3 or only b4 or.............
Another study that showed top ring wear rate increased by the factor (3.5/HTHS)^2.15 for the HTHS viscosity range 2.7-3.5.
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50905 3rd Jan 2011 8:41pm
Naks
LESVOSD110 wrote:
Naks. I forgot,what beer do you drink?No imports please.
Laughing
In Mauritius (where I was born), Phoenix. In SA, Castle Lager Thumbs Up
Post #50954 4th Jan 2011 4:49am
LESVOSD110
Naks wrote:
Laughing
Excellent.I was born and farmed in the Eastern cape,East London.Could you please have a few when you braai sometime.I make my own Biltong,Droewors and Boerewors but no Castle to be found.
I wonder if Caslte will be good for the Puma? Puma 110 SW
90 V8 SOFT TOP
Post #50955 4th Jan 2011 6:02am
Naks
Ah, good old Slammies. I spent 10yrs at Rhodes University, so visited EL quite often.
Can't see why not Rolling with laughter
Post #50962 4th Jan 2011 9:25am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
What do you think about " Total Oil Synthetic Plus" 5w30 ACEA 2002 : A5/B5 " and "Carrefour Synthetique Motor Oil" 5w30 ACEA A5/B5 ?
Does anybody know of these oils ?
Thanks
Post #51925 9th Jan 2011 9:56am
Naks
Theater wrote:
What do you think about " Total Oil Synthetic Plus" 5w30 ACEA 2002 : A5/B5 " and "Carrefour Synthetique Motor Oil" 5w30 ACEA A5/B5 ? Does anybody know of these oils ? Thanks
It seems strange to me that you have such a range of 'supermarket' oils in the EU. In SA you only get the well-known brands, so we tend to stick to them.
Personally I would spend more putting the best engine oil possible in my landy because I intend to keep it forever. My advice: only use the known brands - Castrol, Shell, Mobil, etc.
Post #51945 9th Jan 2011 12:13pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
we have recently got this oil in 5 litre packs in New Zealand instead of drums etc
mobil1 with supersyn, meets ACEA A1/B1 and A5/B5
ford WSS-m2c929-a
Is this oil ok, appears to be on paper
link here
http://neptune.spacebears.com/cars/stories/mobil1.html
and I think this is the same Oil but not sure?
http://docs.google.com/viewer?a=v&q=ca...jeWJnQ1blQ
Post #53808 19th Jan 2011 2:24am
MK
the oil if just fine. There are at least 2 types of synth Mobil 1 5w-30 and both are ok. Mobil 1 ESP 5w-30 has a higher HTHS value which is a bit "less Fuel Efficient". Puma 110" SW
Post #53809 19th Jan 2011 2:33am
sasha2001
Thank you MK Happy Landrovering!!!!!!
Post #53810 19th Jan 2011 6:00am
HardCharger
Just to revive this a bit, why the specific spec on the oil? Aren't our trucks supposed to be able to go to the most remote parts of the world and what not? If you do go to such places, I doubt you'll find the proper spec oil when and if you need it.
That being said, here in the Philippines where I happen to be at the moment, the proper spec oils are as rare as hen's teeth and most oil dealers, local and importers are sometimes difficult to deal with and convince to get the oil so sometimes I have to make due with what I can find. (The closest spec possible, of course) Recently, Shell released a "newer" version of their Helix oil so from 5W-30 the new one is 5W-40, still good then? I'm asking the local Shell guys if they have the Helix Ultra Professional AF 5W-30 as that is what comes out with their oil matcher on their website. Still no news though. Some of the local 2.4 Pumas have run the local Shell 5W-30 no problems, or so I've been told so I guess I should be good?
Post #402291 26th Feb 2015 8:49am
X4SKP
Hi All
Just read this thread... and are some what nervous about posting... but here goes Shocked
1 1/2 years ago I decided to replace my 300tdi and buy in 'near the end' of the current Defender,
after a long look (and research) I decided to go for the latest, best condition, 2.4tdci with the
lowest mileage I could find. In the knowledge that I was going to 'sort' it as best I could into a
a quiet / comfortable, long distance vehicle. DIY Servicing was also a factor.
I think the what Oil Question Question (and supplier) is even harder on the 2.2
but for the 2.4 isn't it more simple Question
I appreciate that some have 'Brand Preferences' mine is based on nothing more than I have
have driven around 250K miles in Land Rovers all on Castrol.
This is whats in mine... have I got it wrong Question
 SKIP
Post #402332 26th Feb 2015 11:33am
Naks
X4SKP, that oil meets the specs, so its fine. --
Post #402335 26th Feb 2015 11:41am
Page 4 of 5 <12345>
