Page 1376 of 1384 <123 ... 137513761377 ... 138213831384>
MarkBrown wrote:
Taken at my local cold water swimming spot, it was a cool 8 degrees in the water.
I really think that that is the best-looking Defender I have seen for a very, very long time, a thing of real beauty! Thumbs Up
Post #1047931 7th Oct 2024 8:43am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Thanks very much! I’ve gone for the restomod style.
Post #1047932 7th Oct 2024 8:57am
L110CDL
AJC wrote:
Took mine to work to do a bit, thought it looked quite at home here
I totally agree with you there Thumbs Up Clayton.
Keeper.
Post #1048174 9th Oct 2024 7:52pm
Stiff1
Stereo
So having seen the coverage on another thread for the single din full screen units which look fantastic, and people's concerns about the lack of buttons, esp when bouncing around in a Defender, thought I would try this....
Wow, what a difference. Works seemlessly via Bluetooth to the head unit, instant connection and operates everything I need while on the move.
Going to see about countersink ING it into the steering wheel "rubber" for a more seemlessly fit but so far so good.
Post #1048527 13th Oct 2024 2:39pm
Stiff1
Stereo
Wow, what a difference. Works seemlessly via Bluetooth to the head unit, instant connection and operates everything I need while on the move and the outer dial to do the volume is fantastic.
Going to see about countersink it into the steering wheel "rubber" for a more seemless fit but so far so good.
Post #1048528 13th Oct 2024 2:41pm
Stiff1
Double post, please delete first, thanks
Post #1048529 13th Oct 2024 2:45pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Quick brew and dog walk on the beach…
 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #1048887 16th Oct 2024 4:18pm
CarMan
+1 to that Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #1048889 16th Oct 2024 4:28pm
Mark0
United States
Finished pulling apart the front end, power-washed the inside of the wings.
Unbelievable how much dirt is built up inside after 35 years 😂. I've been pleased with the general lack of rust though!
Post #1049115 19th Oct 2024 3:24am
That’s some major surgery right there. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #1049134 19th Oct 2024 12:20pm
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
Preparation day
I have been procrastinating changing the front discs as I knew we were gonna get in a fight, me and the Landy. She's 17 years old now and no one has ever removed the hubs on the front axle as far as I can tell. Therefor the drive axle and the drive member is a solid piece of metal with no intentions of letting go from each other.
I've already been through this on the left side so this time I came prepared.
I cut through the member so that the outer ring of it separates from the inner and could be removed.
Then I carefully cut flush to the splines at opposite sides so that the inner ring is cut in half. Then I call for the rest of the family, daughter to apply the brakes and hold the steering wheel, wife to hold the crowbar steady, son to distract everyone by climbing around in the Landy, and me to kick the crowbar with all the force I can. Eventually it let go.
Tried to clean the splines so I could fit the new member but no luck so far.
Tomorrow will see new discs and pads, given that the pistons cooperate.
Cheers!
Post #1049156 19th Oct 2024 4:21pm
Topped up washer fluid today for winter version, needed doing anyway and a little PAS fluid top up too..
Well worth doing at this particular moment whilst the weather is a bit calmer, for now. TheThunder Rolls🇬🇧🇺🇸
Post #1049455 22nd Oct 2024 3:29pm
Replaced rear damper lower bushes today, standard dampers, but soon going to spare some time to fit the pin to pin type instead.
Post #1050278 30th Oct 2024 3:27pm
BrickBox
New rear crossmember stainless bolts and a tidy up. New rear door handle this month to go on.
 2008 2.4 110 Utility Station Wagon XS.
Post #1050514 2nd Nov 2024 9:01am
AJC
Got my steering wheel back from being retrimmed.
New leather and added a green strip at 12 o clock. I quite like it.
Post #1050679 4th Nov 2024 6:41am
