Home > My Defender > What Did You Do In Your Defender Today |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 504 |
Thanks very much! Iโve gone for the restomod style.
Click image to enlarge |
7th Oct 2024 8:57am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10857 |
I totally agree with you there Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
9th Oct 2024 7:52pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 |
So having seen the coverage on another thread for the single din full screen units which look fantastic, and people's concerns about the lack of buttons, esp when bouncing around in a Defender, thought I would try this....
Click image to enlarge Wow, what a difference. Works seemlessly via Bluetooth to the head unit, instant connection and operates everything I need while on the move. Going to see about countersink ING it into the steering wheel "rubber" for a more seemlessly fit but so far so good. Click image to enlarge |
13th Oct 2024 2:39pm |
Click image to enlarge Wow, what a difference. Works seemlessly via Bluetooth to the head unit, instant connection and operates everything I need while on the move and the outer dial to do the volume is fantastic. Going to see about countersink it into the steering wheel "rubber" for a more seemless fit but so far so good. Click image to enlarge Last edited by Stiff1 on 13th Oct 2024 3:20pm. Edited 1 time in total |
13th Oct 2024 2:41pm |
Double post, please delete first, thanks
13th Oct 2024 2:45pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 564 |
Quick brew and dog walk on the beachโฆ
Click image to enlarge Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
16th Oct 2024 4:18pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1875 |
+1 to that Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
16th Oct 2024 4:28pm |
Mark0 Member Since: 12 Oct 2024 Location: Austin, TX Posts: 9 |
Finished pulling apart the front end, power-washed the inside of the wings.
Unbelievable how much dirt is built up inside after 35 years ๐. I've been pleased with the general lack of rust though! Click image to enlarge |
19th Oct 2024 3:24am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
Thatโs some major surgery right there. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
19th Oct 2024 12:20pm |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 48 |
I have been procrastinating changing the front discs as I knew we were gonna get in a fight, me and the Landy. She's 17 years old now and no one has ever removed the hubs on the front axle as far as I can tell. Therefor the drive axle and the drive member is a solid piece of metal with no intentions of letting go from each other.
I've already been through this on the left side so this time I came prepared. Click image to enlarge I cut through the member so that the outer ring of it separates from the inner and could be removed. Click image to enlarge Then I carefully cut flush to the splines at opposite sides so that the inner ring is cut in half. Then I call for the rest of the family, daughter to apply the brakes and hold the steering wheel, wife to hold the crowbar steady, son to distract everyone by climbing around in the Landy, and me to kick the crowbar with all the force I can. Eventually it let go. Click image to enlarge Tried to clean the splines so I could fit the new member but no luck so far. Tomorrow will see new discs and pads, given that the pistons cooperate. Cheers! |
19th Oct 2024 4:21pm |
Topped up washer fluid today for winter version, needed doing anyway and a little PAS fluid top up too..
Well worth doing at this particular moment whilst the weather is a bit calmer, for now. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
22nd Oct 2024 3:29pm |
Replaced rear damper lower bushes today, standard dampers, but soon going to spare some time to fit the pin to pin type instead.
30th Oct 2024 3:27pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 861 |
New rear crossmember stainless bolts and a tidy up. New rear door handle this month to go on.
Click image to enlarge 2008 2.4 110 Utility Station Wagon XS. |
2nd Nov 2024 9:01am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 |
Got my steering wheel back from being retrimmed.
New leather and added a green strip at 12 o clock. I quite like it. Click image to enlarge Click image to enlarge |
4th Nov 2024 6:41am |
