Home > My Defender > What Did You Do In Your Defender Today |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Duplicate post - please delete 1999 Defender TD5 110
13th Aug 2021 8:49am |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 504 |
What have I done today? Finished fitting the LOF uprated output shaft and nailing everything back together, replaced a few oil seals, fitted a set of spring isolators and replaced the handbrake shoes. We are then going to get her out of dry dock and run acceptance trails and once these are done she's off to the fitting out basin for a few interior bits before returning to the fleet for a new commission. Oh woe, oh woe
My crusty old landrover, It will not go. |
13th Aug 2021 2:39pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 757 |
Yesterday rather than today, took our takeaway supper up onto the
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Plain. |
13th Aug 2021 6:25pm |
Broonster Member Since: 14 Dec 2019 Location: West Lothian Posts: 23 |
Busy few days! Fitted a new ORE wheel carrier and replaced the old, scabby steel wheel and ancient tyre with a new matching alloy & BFG tyre.
Also took out the front headlining, covered it, and put it back in. Not decided what I'll do about the sun visors yet though. Also added ClimAir wind deflectors. Definitely the easiest Defender job I've ever done so far! Click image to enlarge Click image to enlarge Click image to enlarge ‘08 Defender 90 Hardtop |
14th Aug 2021 10:24am |
Simboii Member Since: 09 Jun 2021 Location: Carmarthen Posts: 71 |
What do you make of the ORE wheel carrier?? Good piece of kit?
14th Aug 2021 4:44pm |
Yeah, carrier is decent. Really good quality. I've had to retighten it, but think that's normal after it settles in after a few miles. It's a doddle to fit too, even for someone like me! ‘08 Defender 90 Hardtop
14th Aug 2021 5:26pm |
Think i’ll have to invest in one of those then! need to take the strain off from the poor back door on mine!![/b] |
14th Aug 2021 6:29pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 827 |
Tried to change panhard rod, but found out at sometime in the past think bolt was put in reversed so need to lift body off axel then somehow raise axel to allow sufficent movement to get the bolt out, from what I can see, or plan b cut it off Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
14th Aug 2021 9:12pm |
What started off as just replacing a faulty headligh bulb, soon changed into replacing the headlight connector.
Luckily, I had a spare chinese headlight loom I purchased many moons ago so I cut off the plugs leaving a 150mm of wire and soldered onto the exist 110 loom and covered in heat shrink. Time to locate a new H4 3 pin connector. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
19th Aug 2021 6:07pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
where did you get those steps from? great looking truck. |
20th Aug 2021 10:38pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17529 |
This. Delayed over a year by the changes in lifestyle and travelling patterns resulting from Covid.
Click image to enlarge |
22nd Aug 2021 10:01pm |
Congratulations There really should be some sort of trophy, for perseverance if nothing else Darren
23rd Aug 2021 5:30am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
No better place to have it! |
23rd Aug 2021 6:20am |
Took this years apple crop to be pressed and pasteurised.
The crop is well down on last year so we will wait to see how many bottles of juice it produces🙁 Click image to enlarge |
27th Aug 2021 11:47am |
