Page 1321 of 1380 <123 ... 132013211322 ... 137813791380>
excossack
Car alarm decided to go off a few times yesterday.
Had a quick look and interior light not coming on with the door opening.. and then wiggling the switch the light flickered.
Cleaned connections and a bit better.
Light looked dim...tried starting the car. Flat battery.
Popped the battery on charge over night (CTEK-10)
6am this morning I was woken by a beeping noise, and after some investigation, the beeping noise was the Carbon Monoxide alarm in the 110 going off and a reading of 104.
First time I have had the Carbon Monoxide alarm go off while having the battery on charge! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #916665 13th Aug 2021 8:40am
excossack
Duplicate post - please delete 1999 Defender TD5 110
Regards
John M0VAZ
Post #916672 13th Aug 2021 8:49am
Mother superior
What have I done today? Finished fitting the LOF uprated output shaft and nailing everything back together, replaced a few oil seals, fitted a set of spring isolators and replaced the handbrake shoes. We are then going to get her out of dry dock and run acceptance trails and once these are done she's off to the fitting out basin for a few interior bits before returning to the fleet for a new commission. Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #916757 13th Aug 2021 2:39pm
gcc130
Yesterday rather than today, took our takeaway supper up onto the
Plain.
Post #916785 13th Aug 2021 6:25pm
Broonster
Scotland 2008 Defender 90 Puma 2.4 HT Keswick Green
Busy few days! Fitted a new ORE wheel carrier and replaced the old, scabby steel wheel and ancient tyre with a new matching alloy & BFG tyre.
Also took out the front headlining, covered it, and put it back in. Not decided what I'll do about the sun visors yet though.
Also added ClimAir wind deflectors. Definitely the easiest Defender job I've ever done so far!
 ‘08 Defender 90 Hardtop
Post #916888 14th Aug 2021 10:24am
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
What do you make of the ORE wheel carrier?? Good piece of kit?
Post #916960 14th Aug 2021 4:44pm
Broonster
Yeah, carrier is decent. Really good quality. I've had to retighten it, but think that's normal after it settles in after a few miles. It's a doddle to fit too, even for someone like me! Very Happy ‘08 Defender 90 Hardtop
Post #916980 14th Aug 2021 5:26pm
Simboii
Think i’ll have to invest in one of those then! need to take the strain off from the poor back door on mine!![/b]
Post #916991 14th Aug 2021 6:29pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Tried to change panhard rod, but found out at sometime in the past think bolt was put in reversed so need to lift body off axel then somehow raise axel to allow sufficent movement to get the bolt out, from what I can see, or plan b cut it off Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #917010 14th Aug 2021 9:12pm
excossack
What started off as just replacing a faulty headligh bulb, soon changed into replacing the headlight connector.
Luckily, I had a spare chinese headlight loom I purchased many moons ago so I cut off the plugs leaving a 150mm of wire and soldered onto the exist 110 loom and covered in heat shrink.
Time to locate a new H4 3 pin connector. 1999 Defender TD5 110
Regards
John M0VAZ
Post #917814 19th Aug 2021 6:07pm
nitram17
where did you get those steps from? great looking truck.
Post #918070 20th Aug 2021 10:38pm
This. Delayed over a year by the changes in lifestyle and travelling patterns resulting from Covid.
Post #918253 22nd Aug 2021 10:01pm
Congratulations Very Happy There really should be some sort of trophy, for perseverance if nothing else Laughing Darren
Post #918262 23rd Aug 2021 5:30am
gcc130 wrote:
Yesterday rather than today, took our takeaway supper up onto the Plain.
No better place to have it! Cool
Post #918269 23rd Aug 2021 6:20am
gcc130
Took this years apple crop to be pressed and pasteurised.
The crop is well down on last year so we will wait to see how many bottles of juice it produces🙁
Post #918875 27th Aug 2021 11:47am
