![]() | Home > My Defender > What Did You Do In Your Defender Today |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
River crossing at Ravenswick this morning.
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
![]() ![]() ![]() Chris |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5900 ![]() ![]() ![]() |
Finally removed the old front mounts amber twin rotating beacon on the roof rack of the 110 and replaced with 8 LED flashing units mounted under the roof rack. A lot tidier and a bit more stealthy.
![]() Regards John M0VAZ Econet Station 48 no clock |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1856 ![]() ![]() ![]() |
Chased the bodyshop to find out where mine is
![]() Promised me this Thursdy. But thats the third Thursday in a row so I'll not hold my breathe. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Rewired the wireless winch controller so out is out and in is in. When I rewired it while ago, I got the wireless wires on wrong. The wander lead/wired control worked as it should. 1999 Defender TD5 110
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20655 ![]() ![]() |
Gave my air box a clear out.
(Going in for service soon). Managed to find at least four wasps in there. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Fitted Gwyn Lewis arch liners. Rgds.
Chris |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 831 ![]() ![]() ![]() |
Eventually managed to program the new keyfob that I brought and started to clean off some of the underside Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
Finished off my cupboards today...
![]() Click image to enlarge @steve_overland on Insta. 110 expedition vehicle with pop roof |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1368 ![]() ![]() |
Today was fit wheel bearing in a car park after it collapsed on the M56. Luckily it decided to expire at the 300 yard marker so a prompt exit was made
![]() Click image to enlarge ![]() Click image to enlarge |
double post
stinus Member Since: 12 Jul 2020 Location: Kapellen Posts: 12 ![]() ![]() ![]() |
fancy floor, Steve! Did you make the design for the cupboards yourself? I assume by the layout you didn't go for a seating option inside the camper? Do you have a topic where you documented the built up? |
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 ![]() ![]() ![]() |
Started yesterday but finished today after running out of light (and dryness!!!):
A bit of maintenance, had a worn rear top bush and ARB drop link so replaced both on both sides: ![]() Click image to enlarge ![]() Click image to enlarge Also treated myself to a NAS rear step which despite needing fettling (to be expected given LR build tolerances) rather disappointingly didn't come with a complete set of bolts ![]() ![]() Click image to enlarge The observant will notice that this set up is currently useless for towing(!) the tow bar and electrics are still attached to the old drop plate. Having run out of both swear words and skin on my knuckles, I'm happy to leave it in a drive-able state and mount the hardware another day. |
Replaced standard half shafts and drive flanges for one piece units. Whilst there changed the bolts for cap heads.
