Page 1024 of 1384 <123 ... 102310241025 ... 138213831384>
wyvern
Here is the site AJC -
https://www.nakatanenga.de/elektro/geraete...nder?c=115 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #641219 1st Aug 2017 6:51pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Split Charge Install
Not my work. I left it to a professional Thumbs Up
Post #641223 1st Aug 2017 6:59pm
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
Had my 1st breakdown today after more than 2 years of trouble free motoring all my own fault Embarassed ran out of diesel pushed the needle just that bit too far into the red! Also found out that nothing makes spotty teanagers in 10yr old corsas more Censored smug looking than a middle aged man trudging along with a fuel can
Post #641458 2nd Aug 2017 7:01pm
Haha, good old corsa kids!!
When I took the v8 for its first mot after I completed the build, I ran out on the way to the mot station Laughing
Post #641508 2nd Aug 2017 10:36pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Bluest wrote:
I modified the bolts in my Mantec wheel carrier so I can grease the hinges easily. I saw that the Masai carrier comes like this, which gave me the idea. Hole drilled down the centre of the bolt, tapped for a grease nipple and cross drilled about half way down.
They seem to work well, with grease oozing out of the hinges after a few squeezes with the grease gun.
And the nipple is hidden under the standard cap, which keeps it out of the elements.
...could knock a few of them out for forum members 🤔 £? πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #641523 3rd Aug 2017 5:34am
Bought another two Sealey 3T axle stands to complete a full set, on their way for delivery tomorrow. £24 a pair.
Sealey pry bar set, again en-route shortly. Useful for checking bushes etc.
And bought two Wera Joker spanners, an 8mm and 10mm the latter arrived today. (I like them too.) Thumbs Up
Today, noticed the brake light flicker on and off on an incline so it's time for a bit of a brake fluid top up.
May as well shortly check the pads and finally get the steering lock stops adjusted, hopefully the weather will be a bit more stable. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #641650 3rd Aug 2017 4:20pm
red zepplin
Spent an hour and a half trying to fish the interior light switch earth from inside the door pillar #patienceisavertue Evil or Very Mad
Post #642078 5th Aug 2017 7:34pm
BigRuss
Passed the 75,000 mile mark today! Russell
2011MY 110 XS USW Black
Post #642085 5th Aug 2017 8:06pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
It has been a busy defendering day here:
Firstly I finished off fitting the new drag link and track rods. The "originals" needed adjusting and were beyond the help of plus gas or heat to make them relinquish their grip.
Then spent the late afternoon and evening getting the rear axle stripped down ready for a new diff pinion oil seal and flange, new halfshafts and drive members, new oil seals throughout and now as it turns out new stub axles to boot. Big Cry 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #642087 5th Aug 2017 8:09pm
Spent the day representing my 4x4 response group at Camberley fire station open day Cool
 Darren
Post #642104 5th Aug 2017 9:04pm
mini Anaconda
Excellent! ^^^ Thumbs Up Thumbs Up
Today I finished waxing mine ( Embarassed ) and cured the leaky roof gutter. BORG - Bucks & Oxon 4x4 Response Group
Post #642107 5th Aug 2017 9:13pm
L110CDL
Today i finally fixed my new improved snow cowl on ( under maintenance and modification ) section Thumbs Up
As well i finally finished the wiring for my switches ....................
The bottom left switch is to turn the usb and cig socket on/off and the bottom right hand side is to turn my spot light on/off and the top left and right switches are on/off for the heated seats Mr. Green Clayton.
Keeper.
Post #642287 6th Aug 2017 9:10pm
Chris90V8
Switch-tastic mate 😊🖒 πŸšœ. ...... . .... . .. πŸš—πŸšπŸš›πŸššπŸššπŸš—πŸš™πŸš
Post #642296 6th Aug 2017 9:29pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Managed to find the errant tracker box then used the roofrack as an access platform to trim a tall hedge. Then parked the Defender in the road with a few cones and a couple of hazard triangles to reduce the road to a single lane and provide some protection whilst I ventured up a ladder to do some painting.
Post #642302 6th Aug 2017 9:36pm
L110CDL
Laughing Thumbs Up Clayton.
Keeper.
Post #642310 6th Aug 2017 10:14pm
