Page 1018 of 1381 <123 ... 101710181019 ... 137913801381>
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Took the cylinder head off due to strange noises.
Discovered crumbled exhaust/inlet manifold gasket to start with.
Then took the head off as I was convinced something was not right. Gasket looks fine but the small cracks between the valves tell a different story.
New head on order ready for a refit. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #634158 28th Jun 2017 3:53pm
300TDi CSW Phil
Re evaluated gaskets and discovered the following:
Head gasket blowing on Cylinder Nr 4
Exhaust/ inlet manifold gasket, bottom missing on inlet to 1 & 2 and delaminted and cracked on the exhaust of 4
Checked the head................... cracks between valve seats on 3 of 4 cyclinders Big Cry
New head sourced so mainly "Not in the Defender today" as have been swapping all the studs, glow plugs, thermostat and bracketry over.
Nr 3 Injector clamp stud wouldn't come out ....new one ordered.
Nr 2 Injector clamp stud failed as I was torquing it down ... just as well they come as a set of four.
Doesn't look like I'll be doing much in the Defender tomorrow either Big Cry 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #634409 29th Jun 2017 3:26pm
Profyaffle
oh no.. sounds a bit of a nightmare job... Good luck when your new bits come Thumbs Up 1993 200Tdi Defender 90
Post #634416 29th Jun 2017 4:12pm
300TDi CSW Phil
I'm hoping that it should be ok from now on.
Hopefully I will get the bit of power I've been missing back Thumbs Up 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #634417 29th Jun 2017 4:14pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I'm always impressed with the mechanically able on this forum (I can sometimes fix broken humans, I suppose).
Post #634430 29th Jun 2017 4:48pm
The difference being about a £150k a year. Laughing
Post #634450 29th Jun 2017 5:53pm
Doc P
.... Rolling with laughter I wish!
Post #634454 29th Jun 2017 6:00pm
300TDi CSW Phil
I may have some missing knuckles that will need fixing by the end of it Laughing
Not too mention a broken bank account Rolling with laughter 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #634523 29th Jun 2017 9:09pm
300TDi CSW Phil
Well as an update:
I did get in the Defender today rather as well as under the bonnet. Very Happy
New Head Torqued in at 00:15 this morning (that was late enough) so at 9:00 ish it was time to start putting all the hoses and bits back together. Then adjust all the rockers and fit the rocker cover back on.
Top up coolant and then fire her up for the first time in a few days.
Hooray no chuffing noises of any variety (although I can now hear stuff rattling in my mud tunnel tray and cubby).
Once happy that nothing was leaking it was time for a test drive (time to get in). Very Happy
I dont know if a new head needs running in as such so was a bit gentle on the old girl. That said she still pulled like a train far better than she has for months. Everything had obviously gone slowly and I hadn't realised just how much power I was down. Whistle
Time for dinner and a celebratory cider or two (if the Mrs has left any while I have been tinkering). 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #634927 1st Jul 2017 4:32pm
mk1collector
Thumbs Up excellent, well done glad you got it sorted.
I finally cleaned and vacuumed mine out as it was getting rather nasty in there. If we get dry weather again tomorrow I'll give it a wash too Mr. Green Ray
My build thread
Post #634943 1st Jul 2017 6:48pm
L110CDL
On this Friday i had a box delivered which was great and the service was spot on, no grumbles there, cant fault it Very Happy
on opening it up, these 2 items were in there
They are from Raptor Engineering, the switch plate is really well made and the quality is great, as the same goes to the fuse cover Thumbs Up you can have a choice on what you want and as i wanted to put my own switches in i got blanks and all in black to match the rest of the interior.
So this morning i made a start on putting it in, so i stripped all the rubber matting out to reveal the nice original green,
then started measuring and making sure it was in the right place, as in the somewhat limited instructions, and ended up with this
Now you can only have it on one side, the right hand side only, which gives you enough space behind to put sockets in, BUT on the left hand side there is not to much room to put the switches i want to as there is not enough space behind so a rethink is in order Rolling Eyes as the main part of the switches need to be in front of the panel and not behind as i wanted them to be Evil or Very Mad I tried putting the panel to the left but you cant get out the 2 yellow relay things at the bottom and 1 or 2 fuses as well, not good Rolling Eyes After having a good look at this i dont know why they just didn't make it the full width as that is the best option for plenty of space each side Surprised
The next pic's show what i mean when it is one sided
Now the other grumble is that of the fitting snugness where the panel meets the dash panel, not to good, could be better if they had a good look at the way the original fuse panel fits with it's curves, not like the metal panel curves Laughing
Original fuse cover curve
The metal panel cover curve Laughing
The metal panel fitted Shocked not as good as i hoped Rolling Eyes
On a better note the switch panel was a perfect fit as is spot on, old one with a crack
New one fitted Very Happy
PLEASE dont get me wrong, but im am generally happy with the fuse metal panel and will sort something out and you can but different panels, but its not knowing is the hard part as the info on this was limited on the web site so i took the plunge to see what was what Very Happy
I will be ringing them tomorrow to give them some input and to see if they have had any other input on the fuse metal panel Whistle
HAVE any other forum members fitted the metal fuse panel ? Clayton.
Keeper.
Post #635192 2nd Jul 2017 9:09pm
excossack
On the weekend finally got an oil change done.
Tip run.
Discovered play in rear wheel bearing - new bearings on order. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #635241 3rd Jul 2017 7:15am
Huttopia
Picked up the 110 after it had been on holiday for 3 weeks with Listers Droitwich. Reynolds of Rushock did the repair to the bubbling paintwork under warranty and it looks like they have done a decent job, time will tell. Having missed 'Henry' for 3 weeks I took my boy to cricket in the morning and then we went off to the hill climb at Shelsley in the afternoon.
Post #635242 3rd Jul 2017 7:36am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Not today but yesterday spent the day in Kielder Forest running a 4x4 Safari raising money for Mountain Rescue Thumbs Up
 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #635361 3rd Jul 2017 5:32pm
arran jones
Fitted my mm4x4 bolt on diff guard tonight
Post #635418 3rd Jul 2017 8:51pm
