Page 910 of 1382 <123 ... 909910911 ... 138013811382>
ericvv
Post #532462 17th May 2016 7:05pm
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Bought from these chaps...
https://www.facebook.com/truckfixclutches
I opted for the ceramic version due to towing and remap. Trade-off is its not meant to be as progressive as their other offering.
I'm a few weeks from having the car on the road but will report back with findings.
Post #532465 17th May 2016 7:22pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Replaced cracked wing mirror.
15secs to work out how it fitted, and 2mins to do it!
If only all jobs were that simple.
As a bonus one bit of the defender is clean.
 2002 td5 90 county hardtop
Post #532469 17th May 2016 7:32pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Fitted a Skytag tracker. Rather a lightweight effort compared to, say, 'replaced the clutch' Bow down (got to start somewhere I suppose).
Post #532475 17th May 2016 7:43pm
DefenderJon
Northern Ireland 2000 Defender 90 Td5 CSW Epsom Green
Rear shock bushes.
I've noticed recently a bit of a knock going over speed bumps. On investigation, found a bit of movement in the top bushes on the rear shocks.
I should have thought when I was getting the bushes and got new nuts, so had to go and try to source some M12x1.25 nuts for the bottom of the shock. Top nuts are standard M12x1.75.
Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!!
Post #532655 18th May 2016 2:09pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi jaygti, a job I have to do as well, what's the part number and where did you source the mirror from please Cogito ergo sum
Post #532658 18th May 2016 2:15pm
JMG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Stornoway Grey
Went to Saltash
Post #532748 18th May 2016 7:31pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
had the 2 yr service and had a Jag for the day. The Jag was brand new with lots of whizzy lights and stuff but felt small and cramped and soooo low.
Post #532754 18th May 2016 7:38pm
jaygti
@paul55
I got it of eBay from jgs 4x4.
mtc5084 is the part number.
it cost £7.32
Hope this helps. 2002 td5 90 county hardtop
Post #532769 18th May 2016 7:55pm
Paul55
Thumbs Up Cogito ergo sum
Post #532797 18th May 2016 9:04pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
received and fitted within about 2 mins my Bolt on bits TD5 style clear side repeates with Tdi specific moudlings. Coming into the 21st Century sloely but surely.
30 seconds each as plug and play into the bulb holders of the original. Lovely job. TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show!
Post #532823 18th May 2016 10:02pm
Simply
United Kingdom 2012 Defender 110 Puma 2.2 USW Baltic Blue
Said goodbye to our 90 by going out on a couple of local lanes after work.
It's been a great car, I'm going to miss it.
Post #533074 19th May 2016 9:10pm
L110CDL
^ ^ ^ what are going to replace it with ? Clayton.
Keeper.
Post #533078 19th May 2016 9:18pm
Simply
I'm picking up a 110 XS Utility on Saturday Smile
Post #533082 19th May 2016 9:26pm
Pickles
Had you had it long?..what were its specs, and what are the specs of its replacement,...a new one?
Nice pic by the way. Pickles.
Post #533087 19th May 2016 9:48pm
