Home > My Defender > What Did You Do In Your Defender Today |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17462 |
Good plan, thought that might be the back-story!
7th May 2016 9:56pm |
@chopcat. That's making me look at Icom rigs now.
7th May 2016 9:57pm |
Nearly killed my clutch, see here
http://www.defender2.net/forum/topic46263.html All ideas welcome Ray My build thread http://www.defender2.net/forum/topic17615.html |
7th May 2016 10:01pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20468 |
Accidental post, deleted.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
went for a trundle around the Warwickshire country side just to enjoy the scenery and the rain, saw a bad crash with the emergency services in attendance between Lapworth and Knowle a front end flattened VW and a Transit sized van on it side (2 Ambulances in attendance suggesting some poor peoples lives have just altered).
When I got home I looked down at my scan gauge and it showed 39.5 mpg av ! Noted also a defender outside Lookers Solihull, will be passing later today so will get details and a photo or 2 if it is for sale. Keith love your LWT DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
8th May 2016 5:48am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Please can you advise what HT springs are?
8th May 2016 7:56am |
Custom
Can I also ask which springs and dampers you used |
8th May 2016 7:59am |
bm52 - HT springs are springs for the Hard Top Defender, the springs I got were new take off from CSK.
The Dampers, again new take of and all items are Genuine parts. Hope that helps. P.S. If your running factory springs, Spring isolators will give you a minor life all around, if your running Heavy duty springs like mine was it should be about the same. Think mine now is every so slightly higher at the rear and a little lower at the front but exactly as a Factory HT would be only a touch lifted due to the isolators. The turret rings also do but about 5mm |
8th May 2016 11:11am |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 378 |
Crossmember all finished!
Click image to enlarge Click image to enlarge underneath the car is all rust proofed and sealed. Just the rest of the car to go, but all summer to do it! 2002 td5 90 county hardtop |
8th May 2016 3:28pm |
Looking good! DIY underseal is a big undertaking work and time wise and very very dirty.
8th May 2016 4:30pm |
It really was unpleasant.
I originally spent about half an hour and gave up. I then ordered some disposable boiler suits of eBay. 5 for £10. It was much better being completely covered. It's a whole weekends work if you prepare all the metal properly. Still it only cost about £120 total so it was a big saving. And I'm really pleased even though no one can see it! 2002 td5 90 county hardtop |
8th May 2016 5:19pm |
Yes, that's the thing DIY your as good as paid yourself and you know for certain the job is done properly.
8th May 2016 5:31pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Ok, not a Defender but we had a little trundle over the downs in the 80"
Can't beat it with the roof off and screen down Click image to enlarge Click image to enlarge Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
8th May 2016 7:24pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5857 |
Re-fitted the winch after being serviced by Goodwinch - Sounds much better than before. 1999 Defender TD5 110
8th May 2016 7:31pm |
