Page 774 of 1380 <123 ... 773774775 ... 137813791380>
AlexPuma42
Give it a good scrub over weekend not been washed for months! Think half of the farm came off underneath! Now the Mrs can't use the excuse of it being filthy and making us go in her Jap crap!
New Stainless headlight rings tomorrow and add the steps that have been in the garage for 12 month! 110 Hard Top - Izmir Blue
Post #397199 9th Feb 2015 9:43am
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
x-isle wrote:
It might be a fair bit extra but with the hassle of pressing the old one out and pressing a new one in, an extra £20 saves a lot of time and hassle.
Plus this new one has more articulation, not really going to see the benefit of it with the ARB still fitted but also liked the fact it's adjustable and has a grease nipple.
Mite look into getting one of those then as mine is well past it Wink Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #397268 9th Feb 2015 12:43pm
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Heading out for an early ride before heading back to work...m
Post #397568 10th Feb 2015 9:08am
INVSBL
Australia 2015 Defender 90 Puma 2.2 SW Fuji White
hey 100inch,
that external cage looks mint, im a couple weeks off getting my 90, have you had much issues with vicpol with that cage?
Post #397600 10th Feb 2015 12:29pm
Grenadier
Today I've been mostly working and commuting...... Thumbs Up
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #397658 10th Feb 2015 4:19pm
kipperthedog
Towed a very stuck Nissan Cabstar tipper out of a field. I now know that my diffloack linkage needs freeing up but managed without....used nore tow ropes to get far enough away to be oN firmer ground.
A job we gould have both done without but I enjoyed playing with my ropes and shackles (ooer Whistle )
Post #397690 10th Feb 2015 6:27pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Fitted my clear Wipac LED lights, number plate, fog lights and relay, hopefully get my Noldens headlights fitted tomorrow Smile Smile 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #397709 10th Feb 2015 7:14pm
Lorryman100
I thought you were going for Evo 2's John?
Post #397728 10th Feb 2015 7:57pm
jomara
Hi Brian
After seeing your Noldens and comparing them to Evo 2 lights fitted to a Jeep Florida I decided that the Noldens had a better spread and reach of light Shocked Rolling Eyes 2014 110 2.2TDCi XS Station wagon
Post #397748 10th Feb 2015 8:36pm
Venomator
Ven's Fix for White Noise Radio Interference...
Sorted my Alpine unit's white noise interference issue today... Rolling with laughter
But I still need help with it, see >
HERE ... Whistle Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #397767 10th Feb 2015 9:11pm
100inch
INVSBL wrote:
hey 100inch,
Hi INVSBL,
Yes, had the cage (SD from Defender Tuning) finally fitted last week. So far I had no troubles with the law but I will declare it as a roof rack system. Having the small cargo bars over the rear part should hopefully help. Regarding the internal bar I will fit some webbing and put it down as 2nd cargo barrier for the insurance. I want to have it engineered sooner than later. Not really the way to do it but was no longer willing to drive around with a cage. m
Post #397808 11th Feb 2015 1:52am
jmarkha1
United Kingdom 1997 Defender 90 300 Tdi PU Coniston Green
Went through its MOT - no advisories - a result.
Might spoil it to some paint soon - it is currently a number of shades - grey primer, black primer, white and original Green.
Post #397997 11th Feb 2015 8:55pm
excossack
Replaced the MAF sensor. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #398261 12th Feb 2015 7:55pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
250 miles in front wheel drive, still only got 28 to the gallon.
Post #398277 12th Feb 2015 8:40pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
Finally had a free afternoon to finish some electrical work:
- Installed extra fuse box in the under-cubby storage safe along with a number of relays to switch extra electrical users. Initial trigger is taken from the auxiliary below the radio.
- Installed 2 switches near the cup-holders in the cubby box: one to activate the front and rear cameras, and the other to switch on high beam of the Lazer RS4 lights. Cameras were initially switched on by the reverse light, but when maneuvering back and forth it is much nicer to have the image on all the time. Really easy to do now.
- The Lazer lights are enclosed in a new Zunsport grille. I really like the looks of that setup and also the fact that nothing is protruding and the lights cannot be removed without also removing the complete grille. One drawback: fine-tuning the direction of the lights is not so easy Wink
- Installed and wired 3 switches in the under-cubby storage box. One is now used to fully switch off the Lazer RS4 lights (so also DRL is switched off/on). Other switches are already wired to relays for future users like rear working lights.
- Also wired a double USB and extra auxiliary power socket from the fuse box.
- Installed a heavy 5-core and a lighter 3-core cable from under the cubby box to the front bumper. For now it is used to power and switch the Lazer lights and a device to scare off some martens that are terrorizing our neighborhood (and already did some severe damage on 2 of our cars).
Post #398367 13th Feb 2015 7:46am
