Page 753 of 1384 <123 ... 752753754 ... 138213831384>
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
One thing is for sure, you only get a flat tyre when you have you 90 fully loaded. Twisted Evil Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #375873 2nd Dec 2014 6:56pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Took son to be picked up at lyme services M6 then drove back home rather than him leaving the 90 at lyme services all day then ordered a new steering shaft and ball joints as it feels like driving a series on the motorway and everything else has just been done Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #376272 4th Dec 2014 8:03am
excossack
Got the 110 back after a new gearbox, clutch and disco transfer case. Now I need to put back in the interior carpets and cubby box 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #376527 5th Dec 2014 8:31am
JWL
Another job done before the MoT in a couple of weeks. Had a look round the fluid levels a couple of days ago and noticed some play in the UJ's on the steering column, so today a new lower column assembly came in the post and out I went to fit it. It's amazing that when the old one was on the motor there seemed to be no end of play in the upper joint but when I got it off it didn't seem too bad, new one fitted and I'll see how much difference it makes on the school run this afternoon.
On a high note, my Eberspacher is working like a good 'un after I cleaned out the gauze filter on the inlet side of the pulse pump, so much quicker in firing up now and the pump seems a little quieter.
Post #376613 5th Dec 2014 1:49pm
shaggydog
Took the headlining out and put in some thermal/soundproofing insulation.
Hopefully the last time I take my headlining out as it is such a pain in the butt job to do.
Had some (very limited) help from the dog who made it his business that whenever I was cutting the sheet of insulation on the floor it needed sniffing or the side of my face needed licking, or a ball dropped on it so we can go play again. Love him Laughing
Then made a start on lining out the rear loadspace with the same.
Just need to do the bulkhead and doors and we should have a much quieter and warmer (not to mention less condensation) 110 Razz Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #376664 5th Dec 2014 5:45pm
Programmed in my new key fob thanks to Gary @ Alive lending me his diagnostics.
Thumbs Up
Post #376723 5th Dec 2014 11:32pm
cornish rattler
Fitted a new RDX steering wheel Very Happy Graham
Post #376834 6th Dec 2014 5:07pm
bob neville
Took the interior rear side panels off the Tdci SW to enable me to put the two nuts, that have been rattling around behind the trims for the last couple of months, back on the side panel retaining bolts.
Couldn't find the loctite so I am sure I will be repeating the process soon Sad
2013 Defender 90 CSW - sold
Post #376857 6th Dec 2014 5:56pm
excossack
Replaced the bonnet switch, put the carpets back in and the cubby box.
Did a run to the tip and went to get 2 x 16ft 2" ally poles for a HF long wire setup I am doing - but despite being in stock on the website, non left, so ordered two of them 1999 Defender TD5 110
Regards
John M0VAZ
Post #376862 6th Dec 2014 6:13pm
Venomator
SMARTWATER...
Did the SMARTWATER thing all over the place... Whistle
SMARTWATER PROMO OFFER ... Bow down Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #376865 6th Dec 2014 6:19pm
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
Went a bit over the top with the Christmas lights! |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #376868 6th Dec 2014 6:26pm
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
Drove home 240 miles after collecting from Chris (Zagato) who's done an excellent job in protecting both chassis and body Thumbs Up
Post #376881 6th Dec 2014 7:33pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Fitted New brush pack to my wiper motor....all good now Smile Working towards Carry on camping!
Post #376909 6th Dec 2014 9:09pm
Fellrunner - What did he use in the end? Dinitrol and ACF50 amongst some other stuff?
Post #376946 6th Dec 2014 11:58pm
Fellrunner
custom90steve - that's right, dinitrol for the chassis and cf50 and other things for the body - he did the full works, following the water ingress manual etc.
Post #376982 7th Dec 2014 9:52am
