Page 742 of 1380 <123 ... 741742743 ... 137813791380>
excossack
Got 6 pallets from work. The top of the pallets are 18mm ply and measure 23" x 39" ideal for some storage in the back of the landy.(when cut up and re-worked) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #363669 10th Oct 2014 8:57pm
Defender-Stu
Today I pop down to see the guys at Devon 4x4 and picked up a Mudstuff PDH and fitted. Really happy and works well for me and no more burning of my leg on the hand brake
Post #363839 11th Oct 2014 8:22pm
Martin
Site Admin
Got wet. Roof is now leaking, apparently - 14 years isn't bad going I suppose.
Anyone got a 90 CSW roof Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #364186 13th Oct 2014 4:22pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Going to PC world later with a mate to buy a new chest freezer and a small fridge as his old fridge / freezer has packed up and wants to have two seperates instead but will probably need to do two trips Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #364550 15th Oct 2014 12:00am
LR90XS2011
yesterday afternoon popped to Guy Salmon having been told the clutch was finished, new clutch plate, flywheel, pressure plate, slave cylinder/bearing, also new front drive flanges and half shafts,(don't know if this includes CVs didn't see any of the bits so cant post photos. It drove loads better and the play in the transmission has all but gone, the noise from the clutch area has also gone. its a different car just hoping this clutch lasts more than 13k. cant add anything more as I didn't see the parts or know why it needed any of the bits other than the plate. DEFENDER 90 TDCI XS,
Post #364552 15th Oct 2014 4:55am
jimbob7
/\/\/\It's worth popping the cap of the wheel to see if they greased the stub. Pov.spec,ftw. 2006, 110,TD5.
Post #364597 15th Oct 2014 9:30am
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Picked my new defender up form the dealers Smile
Post #364707 15th Oct 2014 5:45pm
excossack
Checked engine oil, topped up coolant, checked PAS, screen wash, brake and clutch fluid.
Changed air filter, and fuel filter.
Started making a bracket mounted off the mudstuff dash to take my Samsung Galaxy Tab in its Brodit mount.
Replaced the power feeds for the split charge with spare cables I had from the winch - I think the wire should be thick enough and replaced the battery connector with bolt clamp ones with a stud attachment for the cable. 1999 Defender TD5 110
Regards
John M0VAZ
Post #364714 15th Oct 2014 6:02pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I've been painting a pair of dirt d-fenders for the 110. May fit tomorrow if it stops raining!
Post #364715 15th Oct 2014 6:05pm
It's 'that' time Martin.....
Post #364738 15th Oct 2014 6:57pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Finally found the cause of the rattle that has been bothering me for the past 4 - 5 months.
Thought it was behind the dashboard, wife said it was my door, checked everything I could, even asked garage to look into it while they had the car sitting around waiting for spare part.
Today I checked again and turned out to be the triangular wheel chock (plastic wing nut holding it in place bit worn at the bottom) and the jack in the battery box.
A bit of high density foam under the wheel chock and around the jack. Did test ride and now no more clanging and clonking when driving over bad roads. Bliss ...
Amazing how sound travels and appears to come from totally different places.
Post #365426 18th Oct 2014 2:02pm
Vizsla
Went to see AJS 4x4 to swap out my Boosts with 235/85/16 Continentals for Black Modulars with GG AT2's (265/75/16). All secured with Wrington's SS Bolts.
Looks much better and no detriment to the steering lock as the bump stops were already adjusted to accommodate the Boosts with Spacers.
Very pleased with the ride quality and low road roar (its all relative in a Defender anyway), although only done about 50miles so far.
Will put the Boosts and tyres up for sale on here if I decide not to keep them....
Post #365452 18th Oct 2014 5:02pm
Rudski
Went shooting! Very strange unseasonably warm weather though made it hard work for the springers.
Post #365464 18th Oct 2014 5:38pm
munch90
fitted mounting bracket in cubby box for coast rechargeable torch wife got me for birthday that's all ive done in defender for over 2 weeks as been to busy to play
recommend the coast torch really bright , 2 spare battery packs come with it , dc,usb,ac charging , better then the led lenser one I got that was more expensive
Post #365469 18th Oct 2014 5:57pm
Venomator
Decided on a Face Lift...
I have not been a fan of the 'Grey' facade presented by my Mamba since I became the new owner in September this year... Embarassed
So, this weekend, decided to do something about it and gave Mamba a much needed Face Lift going from this...
To this... Mr. Green
Courtesy of LRS OffRoad... Bow down
And whilst doing the job, fitted the RDX LED Sidelight units purchased from BoltonBits... Thumbs Up
And finally stuck on this most useful, and least costly of the Add-Ons so far fitted... Rolling with laughter
So, what's next... Shocked
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #365634 19th Oct 2014 12:30pm
