![]() | Home > My Defender > What Did You Do In Your Defender Today |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1728 ![]() ![]() |
Cheers SMB its sitting safely in the drive today watching and waiting in case the blue car comes back
![]() (Its a quiet afternoon at work if you couldn't tell! ![]() ![]() Click image to enlarge Defender puma dormobile camper |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
![]() Prepared A/C pipes for welding in our 130 TD5. I have modiffied the original heater box with new A/C evaporator inside. A/C is a must for me, but standart TD5 bellow the dash is useless, I'm touching it all time with my legs. Second stage will be another one evaporator inside the cab. I'm convetring the 130 HCPU into a long Station Wagon. more pictures here: http://ok2mtm.rajce.idnes.cz/2014_06_11_De...heater_box "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
whats wrong with them Gum?
It think I'm going cross eyed
![]() Somebody had a felt tip out? ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
They shouldn't have left me unsupervised with the vinyl supplies
![]() simple things hey ![]() |
![]() ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82 ![]() ![]() ![]() |
Changed one rear brake disk today - was hoping to do both. Spent ages cleaning the wheel bearings, applied new grease, new gasket, new locknut and measured the disc runout. I was loctiting and torquing up the 5 half shaft retaining bolts and this happened.....
![]() Click image to enlarge Managed to drill and use a stud remover with the hub still attached. Didn't want to take it off again. Was holding my breath whilst ever so gently twisting the stud remover - came out easily. 4 of the bolts torqued up correctly but one just wouldn't click. They were really difficult to remove initially so expect they may have been done up to tight. Off to MJ fews in the morning to buy new bolts - don't fancy that happening again. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
The drive flange bolts can be a nightmare, I have one to drill out at the moment. I think the holes get plugged with gasket gloop and thread locker and the bolts get tightened to yield point on installation.
I now never use threadlocker on these, instead I use spring washers under the heads (it worked fine from 1947 to the 1990s after all). I also use hex socket head capscrews ("Allen bolts") since these are the correct grade, 10.9, and more readily available than hex head. |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Sound deadening material
Took empty wine bottles to the bottle bank (a 110 load space worth o.O) then sat down and started wading through quotes to make my final decision as to who is getting the contract and how far I am going to go!
Maths ![]() |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Put sealant in every conceivable hole/gap above where the sides meet the tub.
Trying to work out how to seal a leaky vent flap now.. Defender 90 XS TD5 (03 Reg) |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Me and son andy made are own rear exhaust section to fit to our new exhaust inc straight through pipe and cutting hole in rear wing for side exiting the exhaust
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
started to fit cruise control ...
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6328 ![]() ![]() ![]() |
Covered 40,000 mile trouble free
![]() ![]() Click image to enlarge |
