Page 695 of 1387 <123 ... 694695696 ... 138513861387>
SailingTom
Cheers SMB its sitting safely in the drive today watching and waiting in case the blue car comes back Laughing
(Its a quiet afternoon at work if you couldn't tell! Thumbs Up )
 Defender puma dormobile camper
Post #337909 13th Jun 2014 12:57pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Prepared A/C pipes for welding in our 130 TD5. I have modiffied the original heater box with new A/C evaporator inside. A/C is a must for me, but standart TD5 bellow the dash is useless, I'm touching it all time with my legs.
Second stage will be another one evaporator inside the cab. I'm convetring the 130 HCPU into a long Station Wagon.
more pictures here: http://ok2mtm.rajce.idnes.cz/2014_06_11_De...heater_box "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #337926 13th Jun 2014 2:49pm
GUM97
Tom- What's going on with the headlights? An engine to TDi for!
Post #337943 13th Jun 2014 5:49pm
SailingTom
whats wrong with them Gum? Shocked
Post #337949 13th Jun 2014 6:13pm
GUM97
It think I'm going cross eyed Rolling with laughter
Somebody had a felt tip out? Whistle An engine to TDi for!
Post #337952 13th Jun 2014 6:21pm
SailingTom
They shouldn't have left me unsupervised with the vinyl supplies Laughing
simple things hey Thumbs Up Defender puma dormobile camper
Post #337954 13th Jun 2014 6:23pm
GUM97
Laughing Simple things, simple minds Whistle Rolling with laughter An engine to TDi for!
Post #337958 13th Jun 2014 6:31pm
Generaldej
United Kingdom 2009 Defender 110 Puma 2.4 CSW Alpine White
Changed one rear brake disk today - was hoping to do both. Spent ages cleaning the wheel bearings, applied new grease, new gasket, new locknut and measured the disc runout. I was loctiting and torquing up the 5 half shaft retaining bolts and this happened.....
Managed to drill and use a stud remover with the hub still attached. Didn't want to take it off again. Was holding my breath whilst ever so gently twisting the stud remover - came out easily.
4 of the bolts torqued up correctly but one just wouldn't click. They were really difficult to remove initially so expect they may have been done up to tight.
Off to MJ fews in the morning to buy new bolts - don't fancy that happening again.
Post #338035 13th Jun 2014 10:53pm
The drive flange bolts can be a nightmare, I have one to drill out at the moment. I think the holes get plugged with gasket gloop and thread locker and the bolts get tightened to yield point on installation.
I now never use threadlocker on these, instead I use spring washers under the heads (it worked fine from 1947 to the 1990s after all). I also use hex socket head capscrews ("Allen bolts") since these are the correct grade, 10.9, and more readily available than hex head.
Post #338040 13th Jun 2014 11:23pm
SkyFallSilver
Kuwait
Sound deadening material
 2016 Defender 90 Adventure Edition
Post #338094 14th Jun 2014 1:10pm
shaggydog
Took empty wine bottles to the bottle bank (a 110 load space worth o.O) then sat down and started wading through quotes to make my final decision as to who is getting the contract and how far I am going to go!
Maths Shocked
Post #338100 14th Jun 2014 1:48pm
Waldo
Put sealant in every conceivable hole/gap above where the sides meet the tub.
Trying to work out how to seal a leaky vent flap now.. Defender 90 XS TD5 (03 Reg)
Post #338120 14th Jun 2014 5:10pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Me and son andy made are own rear exhaust section to fit to our new exhaust inc straight through pipe and cutting hole in rear wing for side exiting the exhaust Very Happy
 Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #338130 14th Jun 2014 6:36pm
started to fit cruise control ...
Post #338142 14th Jun 2014 7:28pm
Caterham
Covered 40,000 mile trouble free Thumbs Up
Post #338163 14th Jun 2014 10:29pm
