![]() | Home > Maintenance & Modifications > Installing a aux power socket in the rear |
I don't think the forum works like that, to be honest, but you could always ask Martin. Darren
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
There must be a way for the administrator to copy a small number of threads/pictures and host them on the site and protect them From Im sure martin will eventually see this and help if he can!
Berni99 Member Since: 02 Jan 2022 Location: Bath Posts: 37 ![]() ![]() ![]() |
Really helpful info on this thread guys. Thanks!
InternationalDBA Member Since: 18 Feb 2018 Location: West Sussex Posts: 35 ![]() ![]() ![]() |
I am fitting a new chassis to my 2008 Defender.
I refitted the loom in the chassis and wired up the NSR lights with no problem. However, on the OSR there is an extra connector at the end of 2 wires, one black and one purple. They are substantial wires and could perhaps take 20 amps as suggested in the post. I spent all afternoon trying to work out where to plug in the connector without success. The connector is under the speaker as suggested so I guess I can just ignore it. It's a shame that I cannot see the original pictures to confirm we are describing the same issue. |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 ![]() ![]() ![]() |
Hi,
Apologies, but what number is the fuse located for this? I’ve had a very quick breeze through, but am really short of time. With thanks |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 214 ![]() ![]() ![]() |
Fuse 2 Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
Bought a charging point with a view at installing an aux socket over the weekend
I have the black and purple wires in a plug ![]() Click image to enlarge ![]() Click image to enlarge Before I break out the hole saw I thought I'd check the electrics, no volts across the plug, found Fuse 2 blown and replaced. But still nothing, tried with the ignition on (thought it was a permanent live) just to see if that would solve the problem. Any suggestions on what else to check? I don't seem to be getting any supply to the heated rear window either, but that's a different fuse and was intact. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
Pulled Fuse 2 again still intact put it back in and checked the voltage 12V now registering.
![]() Click image to enlarge Cut 3 holes in the trim ![]() Click image to enlarge Plate and sockets fitted and connected ![]() Click image to enlarge ![]() Click image to enlarge Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1105 ![]() ![]() ![]() |
