![]() | Home > Technical > Rear side windows leaking |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 ![]() ![]() ![]() |
you could drill out the pop rivets and re-seal it.
Here's a video of the 'start to finish' job, but the but at the end shows the (re-)fitting. I followed this to the 't' to do mine and it worked well. http://www.youtube.com/watch?v=DCYZOe582pg Andy. |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Nice video.......what did you use as a sealant OOI?......Also i dont think i have the seal ring in the video...is that a stock part ?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
You and me both. Mine leaks from where the upright in the middle of the window is attached, I think it gets through the screw. I have resealed around the outside of the frame and I think that has reduced some of the leaks, 1999 Defender TD5 110
The seal ring in the video was part of the 'deluxe' kit (remembering this was not a genuine LR part!).
I used ordinary bathroom silicone sealant if I remember right (I had a tube in the garage at the time) and it has never leaked! I also found this series of videos of how to replace the actual rubbers in the window! Not sure if this is an original LR part or not (and it's a bit patronising!) Part 1 http://www.youtube.com/watch?v=2eCMYe8q_s0 Part 2 http://www.youtube.com/watch?v=N28VXk5JMDM Part 3 http://www.youtube.com/watch?v=k4KsGKrcDhA Part 4 http://www.youtube.com/watch?v=9aGUAPodI0U Part 5 http://www.youtube.com/watch?v=CiJzZanNavo The window kit I used was Britpart (yeah I know) DA4033 and you can buy the seal ring as part DA4032-3SEAL Andy. |
There is only one sealant that I would highly recommend and have used a lot of:-
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
![]() Excellent weapon of choice! Just don't get it on your hands or it'll be there for three to four days! ![]() Treat every day as if it is your last....one day you will be right!! |
I'll do my best.......now all i need are rivets and a rivet gun......expensive this defender owning malarky ....
Putting your location up can often assist in the offers of help by those that may be local to you! Can save you a few £ in tooling and bits 'n' bobs! ![]() Treat every day as if it is your last....one day you will be right!! |
Done.......I can't select the correct colour for my defender as woodcote green isn't in the drop down
It is a available for me to select! ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Looks like I got the last one.
NOT me either? ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 22nd Apr 2013 6:16pm. Edited 1 time in total |
I'm on my iPad, but it's definitely there!
![]() :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
