Home > Technical > Rear side windows leaking |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 |
you could drill out the pop rivets and re-seal it.
Here's a video of the 'start to finish' job, but the but at the end shows the (re-)fitting. I followed this to the 't' to do mine and it worked well. http://www.youtube.com/watch?v=DCYZOe582pg Andy. |
22nd Apr 2013 12:22pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Nice video.......what did you use as a sealant OOI?......Also i dont think i have the seal ring in the video...is that a stock part ?
22nd Apr 2013 12:33pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
You and me both. Mine leaks from where the upright in the middle of the window is attached, I think it gets through the screw. I have resealed around the outside of the frame and I think that has reduced some of the leaks, 1999 Defender TD5 110
The seal ring in the video was part of the 'deluxe' kit (remembering this was not a genuine LR part!).
I used ordinary bathroom silicone sealant if I remember right (I had a tube in the garage at the time) and it has never leaked! I also found this series of videos of how to replace the actual rubbers in the window! Not sure if this is an original LR part or not (and it's a bit patronising!) Part 1 http://www.youtube.com/watch?v=2eCMYe8q_s0 Part 2 http://www.youtube.com/watch?v=N28VXk5JMDM Part 3 http://www.youtube.com/watch?v=k4KsGKrcDhA Part 4 http://www.youtube.com/watch?v=9aGUAPodI0U Part 5 http://www.youtube.com/watch?v=CiJzZanNavo The window kit I used was Britpart (yeah I know) DA4033 and you can buy the seal ring as part DA4032-3SEAL Andy. |
22nd Apr 2013 3:33pm |
There is only one sealant that I would highly recommend and have used a lot of:-
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Apr 2013 3:38pm |
22nd Apr 2013 3:47pm |
Excellent weapon of choice! Just don't get it on your hands or it'll be there for three to four days! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Apr 2013 3:57pm |
I'll do my best.......now all i need are rivets and a rivet gun......expensive this defender owning malarky ....
22nd Apr 2013 4:03pm |
Putting your location up can often assist in the offers of help by those that may be local to you! Can save you a few £ in tooling and bits 'n' bobs! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
22nd Apr 2013 4:08pm |
Done.......I can't select the correct colour for my defender as woodcote green isn't in the drop down 2008 TDCi 2.4 XS CSW
22nd Apr 2013 4:12pm |
It is a available for me to select! An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
22nd Apr 2013 6:06pm |
Looks like I got the last one.
22nd Apr 2013 6:10pm |
NOT me either? Got no W's at all, it goes from Tonga Green to Zambezi Silver even playing around with the year and model. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 22nd Apr 2013 6:16pm. Edited 1 time in total |
I'm on my iPad, but it's definitely there!
:thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
22nd Apr 2013 6:15pm |
