Home > Technical > Rear side windows leaking
johnnyd
Hi All
Just discovered my new landy (1998 TD5) has a leaking rear side window....it is a conversion from a van i think. How easy is the leak to fix, the window is a bit loose, does it need removing and re fitting ? if so any info from anyone on how best to do it ?
JD
Post #229603 22nd Apr 2013 12:13pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
you could drill out the pop rivets and re-seal it.
Here's a video of the 'start to finish' job, but the but at the end shows the (re-)fitting. I followed this to the 't' to do mine and it worked well.
http://www.youtube.com/watch?v=DCYZOe582pg
Andy.
Post #229607 22nd Apr 2013 12:22pm
johnnyd
Nice video.......what did you use as a sealant OOI?......Also i dont think i have the seal ring in the video...is that a stock part ?
Post #229610 22nd Apr 2013 12:33pm
excossack
You and me both. Mine leaks from where the upright in the middle of the window is attached, I think it gets through the screw. I have resealed around the outside of the frame and I think that has reduced some of the leaks, 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #229611 22nd Apr 2013 12:33pm
Andy Jeff
The seal ring in the video was part of the 'deluxe' kit (remembering this was not a genuine LR part!).
I used ordinary bathroom silicone sealant if I remember right (I had a tube in the garage at the time) and it has never leaked!
I also found this series of videos of how to replace the actual rubbers in the window! Not sure if this is an original LR part or not (and it's a bit patronising!)
Part 1 http://www.youtube.com/watch?v=2eCMYe8q_s0
Part 2 http://www.youtube.com/watch?v=N28VXk5JMDM
Part 3 http://www.youtube.com/watch?v=k4KsGKrcDhA
Part 4 http://www.youtube.com/watch?v=9aGUAPodI0U
Part 5 http://www.youtube.com/watch?v=CiJzZanNavo
The window kit I used was Britpart (yeah I know) DA4033 and you can buy the seal ring as part DA4032-3SEAL
Andy.
Post #229637 22nd Apr 2013 3:33pm
K9F
There is only one sealant that I would highly recommend and have used a lot of:-
K9F wrote:
Is it a B & Q stock item you're after or the stuff best suited to your needs? Sikaflex is available on line....
http://www.ebay.co.uk/itm/Sikaflex-291-Fas...2219117121
Sikaflex 29i is for me the best sealant available. If it's good enough for one of these....
It's more than good enough for one of these...
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #229639 22nd Apr 2013 3:38pm
johnnyd
Post #229641 22nd Apr 2013 3:47pm
K9F
^^^^ Thumbs Up
Excellent weapon of choice! Just don't get it on your hands or it'll be there for three to four days! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #229645 22nd Apr 2013 3:57pm
johnnyd
I'll do my best.......now all i need are rivets and a rivet gun......expensive this defender owning malarky .... Smile
Post #229649 22nd Apr 2013 4:03pm
K9F
Putting your location up can often assist in the offers of help by those that may be local to you! Can save you a few £ in tooling and bits 'n' bobs! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #229650 22nd Apr 2013 4:08pm
johnnyd
Done.......I can't select the correct colour for my defender as woodcote green isn't in the drop down Sad 2008 TDCi 2.4 XS CSW
Post #229653 22nd Apr 2013 4:12pm
GUM97
It is a available for me to select! Thumbs Up An engine to TDi for!
Post #229678 22nd Apr 2013 6:06pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Looks like I got the last one.
Post #229680 22nd Apr 2013 6:10pm
K9F
NOT me either? Question Got no W's at all, it goes from Tonga Green to Zambezi Silver even playing around with the year and model. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #229682 22nd Apr 2013 6:10pm
GUM97
I'm on my iPad, but it's definitely there!
:thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  An engine to TDi for!
Post #229683 22nd Apr 2013 6:15pm
