Home > Maintenance & Modifications > CV Joint wear (Title change from Front Diff on the way out?)
Page 3 of 3 <123
jst
as ^^ in a def nothing is linked into the steering position.
it is on all the other LR models though for DSC etc. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224050 2nd Apr 2013 8:36am
x-isle
After reading 2 similar stories on other forums, I'm going to start with putting some grease in the swivel housings to see if it fixes/changes it.
As I've not got any One Shot Sachets to hand could I substitute it with 80/90 Gear oil or 00 Grease?
If this does indeed cure it, I'll probably strip down and rebuild with new CV joints anyway.
Oh and the plug is 1/2 inch square isn't it? Hope so, as I know I've got one of those! Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #224052 2nd Apr 2013 9:15am
jst
you can use EP90 or just by a 600 ccartridge of K48 Moly grease. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224054 2nd Apr 2013 9:27am
x-isle
Cheers James,
Also found this in the workshop manual;
54. NOTE: On later vehicles fill swivel pin housing with 0.33 Litres of Molytex EP 00 grease.
Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #224055 2nd Apr 2013 9:28am
x-isle
FIXED! Mr. Green
Took the filler plug out of the Swivel Housing and popped a cable tie in as a dip stick and although there seemed plenty of grease in there, I added a bit of 80/90 Diff Oil in there. No more noise! Thumbs Up
The swivel doesn't have excessive amount of grease/oil coming out but I suppose 78k miles later and enough to be too dry. As a matter of course I'm going to replace both CVs and all seals.
Once again, a big Bow down to you all for your advice! Craig Rogers
2007 Puma 110 XS
Post #224138 2nd Apr 2013 4:00pm
jst
thats a result
personally though i wouldnt bother changing the CVs. they will be fine. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224215 2nd Apr 2013 8:11pm
x-isle
I'm going to monitor them for the next few days to see if any of the oil comes out.
Could be the placebo effect but steering feels lighter and seems to roll better since. Craig Rogers
2007 Puma 110 XS
Post #224218 2nd Apr 2013 8:20pm
Kev stephenson
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
I had the exact same noise, if you look back through my previous posts you may find the thread from last year some time.
I was advised to change the brass thrust washer in the hub as this affects the float of the drive shaft within. It solved it instantly and only cost a few quid in parts and an hour or 2 in labour. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business
Post #224223 2nd Apr 2013 8:33pm
jst
def is. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224224 2nd Apr 2013 8:33pm
jst
[quote="Kev stephenson" brass thrust washer in the hub [/quote]
in the end of the stub? can be cheaper to just change the whole stub sometimes if your paying for labour. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224228 2nd Apr 2013 8:37pm
x-isle
If you buy a CV kit, you get the brass washer included. Craig Rogers
2007 Puma 110 XS
Post #224256 2nd Apr 2013 9:31pm
Page 3 of 3 <123
