Home > Maintenance & Modifications > CV Joint wear (Title change from Front Diff on the way out?) |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
After reading 2 similar stories on other forums, I'm going to start with putting some grease in the swivel housings to see if it fixes/changes it.
As I've not got any One Shot Sachets to hand could I substitute it with 80/90 Gear oil or 00 Grease? If this does indeed cure it, I'll probably strip down and rebuild with new CV joints anyway. Oh and the plug is 1/2 inch square isn't it? Hope so, as I know I've got one of those! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Apr 2013 10:15am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7876 |
you can use EP90 or just by a 600 ccartridge of K48 Moly grease. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Apr 2013 10:27am |
Cheers James,
Also found this in the workshop manual; 54. NOTE: On later vehicles fill swivel pin housing with 0.33 Litres of Molytex EP 00 grease. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Apr 2013 10:28am |
FIXED!
Took the filler plug out of the Swivel Housing and popped a cable tie in as a dip stick and although there seemed plenty of grease in there, I added a bit of 80/90 Diff Oil in there. No more noise! The swivel doesn't have excessive amount of grease/oil coming out but I suppose 78k miles later and enough to be too dry. As a matter of course I'm going to replace both CVs and all seals. Once again, a big to you all for your advice! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Apr 2013 5:00pm |
thats a result
personally though i wouldnt bother changing the CVs. they will be fine. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Apr 2013 9:11pm |
I'm going to monitor them for the next few days to see if any of the oil comes out.
Could be the placebo effect but steering feels lighter and seems to roll better since. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Apr 2013 9:20pm |
Kev stephenson Member Since: 27 Feb 2012 Location: Huddersfield Posts: 56 |
I had the exact same noise, if you look back through my previous posts you may find the thread from last year some time.
I was advised to change the brass thrust washer in the hub as this affects the float of the drive shaft within. It solved it instantly and only cost a few quid in parts and an hour or 2 in labour. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys 1996 130 300TDi chip truck for tree surgery business |
2nd Apr 2013 9:33pm |
def is. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
[quote="Kev stephenson" brass thrust washer in the hub [/quote]
in the end of the stub? can be cheaper to just change the whole stub sometimes if your paying for labour. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Apr 2013 9:37pm |
If you buy a CV kit, you get the brass washer included. Craig Rogers
2nd Apr 2013 10:31pm |
