Home > Maintenance & Modifications > Rear Work Light
Page 5 of 6 <123456>
BlackFender
Austria 2013 Defender 110 Puma 2.2 USW Aintree Green
Delete 2013 110 TD4 SW Utility
1997 110 Tdi300 Hard Top
2013 90 TD4 Hard Top (trashed)
Post #831601 17th May 2020 4:45pm
macfrank
Seems there is none from MY2013 onwards.
Please see here https://www.defender2.net/forum/post797329.html#797329
Post #831627 17th May 2020 6:53pm
BlackFender
Great! Cheers! Will check it tomorrow. 2013 110 TD4 SW Utility
Post #831671 17th May 2020 9:24pm
Pacha
If it helps, I am in the process of fitting the Labcraft, currently have some paint stuff to fix and relocate the rear screen washer jet.
Will feedback once I get some progress. Rgds.
Chris
Post #831685 17th May 2020 10:52pm
geezer
Australia 2011 Defender 90 Puma 2.4 SW Zermatt Silver
If you are just looking for a bit more reversing light, then I just replaced my rear fog light for another reversing light which already has a dash switch. Which is ok here in Queensland as we rarely see fog.
Not sure how that goes with MOT's, reg's etc over in the UK though, but takes 5 mins to swap over if so inclined, food for thought.
Post #831704 18th May 2020 6:46am
BlackFender
Hi, great stuff!
I have already mounted the lamp assembly. I did not mount the washer jet in the left corner as I had previous on my 90. I went for that solution.
I think it will give a better distribution of the washer liquid.
I thought of having on switch at the dash board and maybe a second one on the speaker housing for camping.
PS: Replacing the rear fog light definitely doesn't work here in Europe! Laughing 2013 110 TD4 SW Utility
Post #831707 18th May 2020 7:09am
BlackFender
I finally found the purple wire on my MY13 Defender! Very Happy
It terminates in the female part of the wiring loom. Now I need to find the right terminal to get it connected via the male connector of the towing bar loom. 2013 110 TD4 SW Utility
Post #831923 19th May 2020 8:25am
macfrank
Not sure if this was answered somewhere, but I found out the required plug is
Sumitomo DL Sealed Series 090/187 (2.3/4.8mm) HYBRID 9-way Male Housing, Sumitomo Part No. - 6195-0173
„ You will also need 7 x 090(2.3mm) and 2 x 187(4.8mm) Male Terminals, with the appropriate Wire Seals for each Terminal, and 2 x 090 Cavity Plugs for the two unused ways.“
Sumitomo‘s site seems to be down or the link outdated
http://swsct.sws.co.jp/components/en/housi...1950173dls
Funny thing: when I googled for an alternative source I got this rather old thread:
https://www.defender2.net/forum/post37571.html
If you find a link to buy these, I‘d be interested, too.
Or maybe Martin can help?
Post #831985 19th May 2020 2:34pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
PaulMc on here sells most of these connectors, worth asking him. He also sells via Ebay, landroverconnectors, I think.
Post #832014 19th May 2020 5:36pm
Pacha
Installed today.
Used a 12v LED controller from eBay (less than £10) and wired into permanent live lurking in the rear offside panel.
Works a treat and has a dimmer function on the remote.
 Rgds.
Chris
Post #832428 21st May 2020 6:54pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Thumbs Up
Nice!
Post #832458 21st May 2020 8:12pm
BlackFender
Thank you guys for the very usefull information. landroverconnectors is not doing buisness at the moment but I found another supplier. Ordered some terminals today to get the 12V out of the loom without cutting any wires.
Will post if it worked.
@macfrank: I ordered some more. If it works I can send you the respective terminal! Very Happy 2013 110 TD4 SW Utility
Post #832539 22nd May 2020 10:14am
macfrank
„ @macfrank: I ordered some more. If it works I can send you the respective terminal! „
Very Happy Thumbs Up
That‘s so kind of you!
Post #832545 22nd May 2020 10:25am
BlackFender
Pacha wrote:
Installed today.
Great job! The dimmer seems to be great for camping as the Scene Light is quite bright. Good for working though, but maybe less desireable when drinking red wine in the evening... 2013 110 TD4 SW Utility
Post #832551 22nd May 2020 10:56am
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
Pacha wrote:
Installed today.
Was thinking about fitting a Labcraft Scenelight in a smilar method, what's the light quality (brightness & spread) like when fitted? Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #832666 22nd May 2020 5:53pm
