![]() | Home > Maintenance & Modifications > Rear Work Light |
Thanks when or if it stops raining and dries out, I'll check that out.
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2326 ![]() ![]() ![]() |
I bought an LED worklamp with the intention of bolting it to the the back of my 90 as is conventionally done but was persuaded by a friends set up to mount it on a couple of little brackets that hang from the gutter. With the addition of a length of twin core, a 12v plug and socket from Mud UK I now have a lamp that will hang from the gutter anywhere around the sides and back of the 90. Very handy when camping
![]() Mo ![]() Click image to enlarge The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Mo Murphy- Brilliant Idea!
May have to copy that in the future ![]() |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 430 ![]() ![]() ![]() |
i have used my heated rear screen wiring for the worklights, i have klandy glass now mind and it works a treat, no extra buttons etc on the dash either!!!
StuLandy Member Since: 28 Jul 2012 Location: Here, there and Everywhere!! Posts: 43 ![]() ![]() |
Again, another up date. Rear light fitted as per Craigs drawing and piccys. Spot on. Works a treat. I havent put the second switch in as the wiring to the front I think would be a bit raggy if no route is a available. But again thanks too all.
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Close
I wired my led worklight with switch and relay switch on inside to use as worklight for trailer loading camping etc and wired to reverse light so comes on when in reverse but reverse light not on when work light switched on ..both on to reverse only work on when switched on.
using led light means you can use much thinner wire ..and when I fitted mine I used stainless steel bolt then drilled through bolt (on lathe) and ran wire through centre of bolt and you don't have another hole with gommet in your body work looks much neater |
Skippy Blue Member Since: 26 Aug 2013 Location: Dartmoor Posts: 14 ![]() ![]() ![]() |
Has anyone tried the LED "scene light" from Mudstuff - it looks to be quite discrete and not as vulnerable as a classic style work lamp? ... Or one of the similar flush fitting LED light bars?
Thinking of wiring one in with a dashboard switch so I can use it either for real work light duties or as an occasional supplement for tricky night-time reversing. |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Excuse my ignorance - but what is klandy glass ? |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I have 2 of these http://4x4overlander.com/lights/lightforce-stubby-worklight.html bought from 4x4 Overlander (site sponsor). All you need is an extra 1 or 2 accessory sockets & some extension cable.
They can be positioned anywhere, & removed when not needed. ![]() |
anybody tried the new MUD rear work lamp? ive been looking for a surface mount solution for a while as it cant snag anything etc.
![]() Click image to enlarge http://www.mudstuff.co.uk/products/electri...e-s17.html |
Hock Member Since: 12 Sep 2011 Location: Yorkshire Posts: 133 ![]() ![]() ![]() |
Anyone know if the rear demister would be wired on a 90 pickup the same as the DC's were?
Would also like to know that. Thinking whether one could be fitted to the lower frame of a Patriot rack. |
BlackFender Member Since: 01 Nov 2018 Location: Vienna Posts: 13 ![]() ![]() ![]() |
Hi guys!
Wanted to wire up my Labcraft Scenelight on the back of my MY13 Utility, opened the right speaker housing to get the feed from the purple/black connector... Just there is none! ![]() Anyone had thic problem before? Thanks! ![]() Click image to enlarge 2013 110 TD4 SW Utility 1997 110 Tdi300 Hard Top 2013 90 TD4 Hard Top (trashed) Last edited by BlackFender on 22nd May 2020 7:12pm. Edited 3 times in total |
