![]() | Home > Maintenance & Modifications > Rear Work Light |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Most of the bits were left over from my Motor Racing days, however, this should give you a few ideas;
2 switches, 1 for the front, 1 for the back; (although mine doesn't have the print); http://www.ebay.co.uk/itm/12V-Car-Dashboar...3cce307957 Fuse box, this is the type I used, but there are many others; http://www.ebay.co.uk/itm/4-Way-Circuit-St...27bec27e49 Relay, this has it's own bracket, but I chose for a socket; http://www.ebay.co.uk/itm/12V-RELAY-4-PIN-...41691b6b5d Relay socket; http://www.ebay.co.uk/itm/Black-Relay-Base...20c5aa28e2 The wire doesn't have to be too big as the amp is low, however, again, I already had some wire which is equivalent to 8 or 10 AWG. It doesn't need to be this big. The draw is only going to be a few amps for a single light, so even 14 AWG should be good enough. If you want to add a warning LED like I have, then any 12V LED will do. I chose a flashing one. However, you could also just get a switch with a warning light built in. Plenty of crimps The only other things you may need is insulating tape and I stuck the fusebox and relay mount with 3m pads rather than drilling. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
StuLandy Member Since: 28 Jul 2012 Location: Here, there and Everywhere!! Posts: 43 ![]() ![]() |
Cheers Craig, that'll do nicely...
Bits Ordered, now for the wiring skills..
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20696 ![]() ![]() |
Still don't know why manufacturers haven't cottoned on to using hollow mounting bolts. Such a neat way of cable routing and so much easier to boot as well. I'd have had a couple already by now if it wasn't for that. An added annoyance is you can't buy them easy either (the hollow bolts). TheThunderRollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Thanks for the reminder Steve, I meant to do something about it when we discussed it a while back, maybe I'll actually do something now! ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Like what? TheThunderRollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Sourcing hollow bolts
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 ![]() ![]() |
Because in the sizes we're talking about, they'd be very easy to over-torque and snap. Especially in the the cheese-like A2-70 grade of stainless they're normally supplied with. Five-minute job if you have access to a lathe though... Real trucks don't have spark plugs |
Supply with torque setting on paper and then there would be no problem. I have seen one on D44's site with hollow bolt but it was only a single unit and I didn't like the actual unit anyway. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Don't worry, am sure Entreq will shortly be offering a worklight made of aerospace-grade unobtainium, with neatly routed and potted cables disappearing through the mounting bolt, and it will only cost 400.... ![]() |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
![]() ![]() thnks Craig www.newfoundland.gr |
Looks like on that circuit that both switches have to be on in order to power the light? That could be a PITA? Is there a way of turning the light on or off from either switch indepently? |
No, it's either/or, just like a 2 way switch at home. So does exactly as you want. Craig Rogers
Gotcha. Cool setup. |
