Home > Maintenance & Modifications > Rear Work Light
Page 2 of 6 <123456>
StuLandy
2008 Defender 110 Puma 2.4 CSW Alpine White
Craig, have you got a material list and a possible place that you purchased the electrical items from..
Post #219937 17th Mar 2013 6:11pm
x-isle
Most of the bits were left over from my Motor Racing days, however, this should give you a few ideas;
2 switches, 1 for the front, 1 for the back; (although mine doesn't have the print);
http://www.ebay.co.uk/itm/12V-Car-Dashboar...3cce307957
Fuse box, this is the type I used, but there are many others;
http://www.ebay.co.uk/itm/4-Way-Circuit-St...27bec27e49
Relay, this has it's own bracket, but I chose for a socket;
http://www.ebay.co.uk/itm/12V-RELAY-4-PIN-...41691b6b5d
Relay socket;
http://www.ebay.co.uk/itm/Black-Relay-Base...20c5aa28e2
The wire doesn't have to be too big as the amp is low, however, again, I already had some wire which is equivalent to 8 or 10 AWG. It doesn't need to be this big. The draw is only going to be a few amps for a single light, so even 14 AWG should be good enough.
If you want to add a warning LED like I have, then any 12V LED will do. I chose a flashing one. However, you could also just get a switch with a warning light built in.
Plenty of crimps
The only other things you may need is insulating tape and I stuck the fusebox and relay mount with 3m pads rather than drilling. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #220153 18th Mar 2013 11:10am
StuLandy
Cheers Craig, that'll do nicely... Cool
Post #220202 18th Mar 2013 4:07pm
StuLandy
Bits Ordered, now for the wiring skills.. Confused
Post #220221 18th Mar 2013 5:32pm
Still don't know why manufacturers haven't cottoned on to using hollow mounting bolts. Such a neat way of cable routing and so much easier to boot as well. I'd have had a couple already by now if it wasn't for that. An added annoyance is you can't buy them easy either (the hollow bolts). WeWillWin🇬🇧🇺🇸
Post #220222 18th Mar 2013 5:35pm
GUM97
Thanks for the reminder Steve, I meant to do something about it when we discussed it a while back, maybe I'll actually do something now! Laughing An engine to TDi for!
Post #220230 18th Mar 2013 6:03pm
Like what? WeWillWin🇬🇧🇺🇸
Post #220236 18th Mar 2013 6:11pm
GUM97
Sourcing hollow bolts Very Happy There's a product discharge equipment company that I use at work, and they use hollow bolts in some places, and I was going to ask them about suppliers!.. An engine to TDi for!
Post #220237 18th Mar 2013 6:20pm
udderlyoffroad
Because in the sizes we're talking about, they'd be very easy to over-torque and snap. Especially in the the cheese-like A2-70 grade of stainless they're normally supplied with.
Five-minute job if you have access to a lathe though... Real trucks don't have spark plugs
Post #220239 18th Mar 2013 6:23pm
Supply with torque setting on paper and then there would be no problem. I have seen one on D44's site with hollow bolt but it was only a single unit and I didn't like the actual unit anyway. Confused WeWillWin🇬🇧🇺🇸
Post #220269 18th Mar 2013 8:18pm
udderlyoffroad
Don't worry, am sure Entreq will shortly be offering a worklight made of aerospace-grade unobtainium, with neatly routed and potted cables disappearing through the mounting bolt, and it will only cost �400.... Razz Real trucks don't have spark plugs
Post #220308 18th Mar 2013 9:53pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
x-isle wrote:
Bow down Bow down at last!!!!!
thnks Craig www.newfoundland.gr
Post #220488 19th Mar 2013 8:25pm
mikeh501
pouf wrote:
thnks Craig
Looks like on that circuit that both switches have to be on in order to power the light? That could be a PITA? Is there a way of turning the light on or off from either switch indepently?
Post #220525 19th Mar 2013 9:59pm
x-isle
No, it's either/or, just like a 2 way switch at home. So does exactly as you want. Craig Rogers
2007 Puma 110 XS
Post #220527 19th Mar 2013 10:03pm
mikeh501
Gotcha. Cool setup.
Post #220532 19th Mar 2013 10:15pm
