Home > Maintenance & Modifications > MUD DEFENDER ROOF CONSOLE
Page 7 of 8 <12345678>
dysfunctional pigeon Thumbs Up
Post #334459 29th May 2014 7:29pm
I've had 2 screens fitted since fitting the Mud console and it didn't interfere with the fitting at all.
Post #334503 29th May 2014 9:56pm
Hence the (may) mine is tight to the rubber , the fitter might have been very cautious I needed to tidy the GPS & BlackVue wires any how Thumbs Up
I'd rather the fitter ask than damage anything
Post #334520 30th May 2014 5:19am
Sorry, Ken, I didn't mean to sound argumentative! I was trying to reinforce your "may" but probably chose my words poorly. Thumbs Up
Post #334538 30th May 2014 8:18am
No Offence taken at all Thumbs Up
Post #334543 30th May 2014 8:50am
HardCharger
myonehere wrote:
yes they look good and are very useful - I put a sunglasses holder in the centre of mine - with the rear view camera monitor alongside. And a useful grab handle over the passenger ....
Nice! Curious about the grab handle, can it take the full weight of a person? Will it hamper ingress and egress? Where is it attached to? Where'd you get it?
Post #395034 2nd Feb 2015 3:40am
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
yes - it is bolted through to plate I attached to the inside lip [behind trim]. The handle was amongst my pile of old parts - Rover I think. No, it doesnt hamper access....
Post #399044 15th Feb 2015 5:11pm
Venomator
Holy Old Thread Revival...
Sorry to drag up another old thread, but it seemd logical, rather than starting another, as just caught up on this one after having been looking at the MudStuff Console, which unfortunately did not come back in stock, coincidentally, until their recent discount finished... Evil or Very Mad
After reading all the recommendations here, I have just ordered the new Black version for Ven's Keswick Special... Mr. Green
Hopefully fitting will be a doddle for this numpty, although I am seriously tempted to have it done by the professionals, while they still have the Special in build... Rolling with laughter
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #459498 1st Oct 2015 9:43am
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
I was just wondering if i can fit the Mud roof console if i dont have a headlining on my 90 hardtop in the first place......would it fit anyway? appreciate your experiences
thanx Happy Travel
www.thegippo.wordpress.com
Post #565801 22nd Sep 2016 2:52pm
Bug
Drilling door frames
I know the rear washer pipework and some wiring runs above the doors - near side or both? Does anybody have any advice for drilling the door frame and fitting the self tappers without risking damage to pipe/wiring? Hoping to fit mine sometime next eek.
Post #599065 4th Feb 2017 2:28pm
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
The wires and rear wash pipe can be lifted away so the drill bit doesn't interfere with them.
May be worth using a bit of tape to hold them out of the way if you are doing the job solo! Sandy
Post #599070 4th Feb 2017 3:18pm
Bug
The joys of a 64 plate 110XS, I was hoping not to have remove some of the internal trim and open up the side of the headlining for access.
Post #599074 4th Feb 2017 3:30pm
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Maybe the first stage of the fitting instructions (fir tree removal) is to clear away the pipes and wires?
Thinking of getting one of these........is it easy to run extra wiring to the console? Can interior light circuit take any heavier loading? Just for phone/ipod charging.
Post #663494 11th Nov 2017 5:42pm
Bug
Moving the headlining to tape the wires and pipes out of the way was easy and fitting was straightforward, even without any help.
I didn't plumb in any extra electrics and not sure how much load you could put on the interior lamp cct as, although it's on a 10A fuse with lots of other stuff, the cabling is quite small.
Post #663504 11th Nov 2017 6:12pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
x-isle wrote:
I doubt it will fit without cutting the headlining.
I've got a basic Maxon CM10 which is 180mm deep and needed to cut the headlining.
I don't see an issue with cutting a small hole in the headlining if the roof console is never going to be removed again. You can't see it.
Hi Craig,
Do you have a picture of the CM10 fitted?
I am thinking of buying the MUD roof console to fit a Midland Alan 48 Pro that is W154 x H50 x D175
I am happy to cut the headlining but I wonder at what point the back of the unit will actually touch the skin of the roof?
Yan
Post #853604 1st Sep 2020 1:56pm
