Home > Maintenance & Modifications > MUD DEFENDER ROOF CONSOLE |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
dysfunctional pigeon
29th May 2014 7:29pm |
Hence the (may) mine is tight to the rubber , the fitter might have been very cautious I needed to tidy the GPS & BlackVue wires any how
I'd rather the fitter ask than damage anything |
30th May 2014 5:19am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17351 |
Sorry, Ken, I didn't mean to sound argumentative! I was trying to reinforce your "may" but probably chose my words poorly.
30th May 2014 8:18am |
No Offence taken at all
30th May 2014 8:50am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 731 |
Nice! Curious about the grab handle, can it take the full weight of a person? Will it hamper ingress and egress? Where is it attached to? Where'd you get it? |
2nd Feb 2015 3:40am |
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 |
yes - it is bolted through to plate I attached to the inside lip [behind trim]. The handle was amongst my pile of old parts - Rover I think. No, it doesnt hamper access....
15th Feb 2015 5:11pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Sorry to drag up another old thread, but it seemd logical, rather than starting another, as just caught up on this one after having been looking at the MudStuff Console, which unfortunately did not come back in stock, coincidentally, until their recent discount finished...
After reading all the recommendations here, I have just ordered the new Black version for Ven's Keswick Special... Hopefully fitting will be a doddle for this numpty, although I am seriously tempted to have it done by the professionals, while they still have the Special in build... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
1st Oct 2015 9:43am |
sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96 |
I was just wondering if i can fit the Mud roof console if i dont have a headlining on my 90 hardtop in the first place......would it fit anyway? appreciate your experiences
thanx Happy Travel www.thegippo.wordpress.com |
22nd Sep 2016 2:52pm |
Bug Member Since: 03 Mar 2016 Location: Hayling Island Posts: 19 |
I know the rear washer pipework and some wiring runs above the doors - near side or both? Does anybody have any advice for drilling the door frame and fitting the self tappers without risking damage to pipe/wiring? Hoping to fit mine sometime next eek.
4th Feb 2017 2:28pm |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 313 |
The wires and rear wash pipe can be lifted away so the drill bit doesn't interfere with them.
May be worth using a bit of tape to hold them out of the way if you are doing the job solo! Sandy |
4th Feb 2017 3:18pm |
The joys of a 64 plate 110XS, I was hoping not to have remove some of the internal trim and open up the side of the headlining for access.
4th Feb 2017 3:30pm |
chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264 |
Maybe the first stage of the fitting instructions (fir tree removal) is to clear away the pipes and wires?
Thinking of getting one of these........is it easy to run extra wiring to the console? Can interior light circuit take any heavier loading? Just for phone/ipod charging. |
11th Nov 2017 5:42pm |
Moving the headlining to tape the wires and pipes out of the way was easy and fitting was straightforward, even without any help.
I didn't plumb in any extra electrics and not sure how much load you could put on the interior lamp cct as, although it's on a 10A fuse with lots of other stuff, the cabling is quite small. |
11th Nov 2017 6:12pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 407 |
Hi Craig, Do you have a picture of the CM10 fitted? I am thinking of buying the MUD roof console to fit a Midland Alan 48 Pro that is W154 x H50 x D175 I am happy to cut the headlining but I wonder at what point the back of the unit will actually touch the skin of the roof? Cheers Yan |
1st Sep 2020 1:56pm |
